Page 3 of 12 1 2 3 4 5 11 12
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918331
09/23/15 08:32 PM
09/23/15 08:32 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
This is a great post, very interesting with lots of people watching. Good Luck !
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918337
09/23/15 08:39 PM
09/23/15 08:39 PM
USA
hudsonhornet7x Offline
USA
This just might be what Moparts is supposed to be. I am a big block guy bt I find the ritter idea to be very interesting as well. Lots of luck and the more detail the better!
Re: 420cid build with a new Ritter Aluminum Block [Re: hudsonhornet7x] #1918378
09/23/15 09:44 PM
09/23/15 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What is the deck height and lifter angle on these
blocks
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918429
09/23/15 10:34 PM
09/23/15 10:34 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Good luck, hope it works out as we sb guys need something for blocks.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 420cid build with a new Ritter Aluminum Block [Re: MR_P_BODY] #1918482
09/23/15 11:31 PM
09/23/15 11:31 PM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
blocks
wave
This one is a tall deck (9.6") 48 deg. you can get a short deck and what ever lifter angle.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918490
09/23/15 11:46 PM
09/23/15 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By 69 lawndart
[quote=MR_P_BODY]What is the deck height and lifter angle on these
blocks
wave
This one is a tall deck (9.6") 48 deg. you can get a short deck and what ever lifter angle. [/quot
What you have is what I'm looking for... thats why
I will watch your build... I have a set of W-9 for
one
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918501
09/24/15 12:04 AM
09/24/15 12:04 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Good luck and I beleive most of the horror stories come from the iron blocks.
Anyway I am also interEstes in this build.
Re: 420cid build with a new Ritter Aluminum Block [Re: MR_P_BODY] #1918510
09/24/15 12:20 AM
09/24/15 12:20 AM
Kansas, Topeka
Kansas, Topeka
blocks
wave
one
wave
I have a set of W9's on my other R3 block (468 cid) with 59 deg lifter angle. That set of heads is a set of Chapman done heads and they are to small for that motor it gives up at 6800 but it pulls hard in the mid range.
This one is going to get the W9RP that Curtis Boggs from RFD did.
W9RP
w9rp 2
Re: 420cid build with a new Ritter Aluminum Block [Re: fishy340] #1918511
09/24/15 12:21 AM
09/24/15 12:21 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Not to mention aluminum is easier to fix
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918513
09/24/15 12:24 AM
09/24/15 12:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
blocks
wave
one
wave
This on is going to get the W9RP that Curtis Boggs from RFD did.
My set is the standard Chapmans they ported... I wasnt
gonna go that big
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1918531
09/24/15 12:53 AM
09/24/15 12:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2... never saw my W5 head that I tried to have repaired did you. Some aluminum..... well, isn't.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918532
09/24/15 12:55 AM
09/24/15 12:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
are these blocks actually for sale?? I remember the other attempt at building one it was mentioned it was a "prototype".
Re: 420cid build with a new Ritter Aluminum Block [Re: J_BODY] #1918536
09/24/15 12:59 AM
09/24/15 12:59 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I hope to have some info after this weekends race if the same guy shows up that I was introduced to at last years race. If not I should still have a contact number.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 420cid build with a new Ritter Aluminum Block [Re: pittsburghracer] #1918542
09/24/15 01:05 AM
09/24/15 01:05 AM
Kansas, Topeka
Kansas, Topeka
Yes I think the blocks are for sale, all I did was E-mail him. I know last time I spoke with him he said that the foundry was having problems casting the steel blocks because of core shift, but the aluminum blocks they weren't having problems with. I was told that the other aluminum block that is running is the prototype block.
Re: 420cid build with a new Ritter Aluminum Block [Re: J_BODY] #1918545
09/24/15 01:17 AM
09/24/15 01:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Isnt that the truth... my first set had so much crap
in the alum that it was useless to even try... when
I got my replacement set from mopar they said I could
keep them... I tried to weld on them..what a joke....
the set I have now is pretty porous but seal.. with
some work
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918607
09/24/15 05:10 AM
09/24/15 05:10 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Yes you can buy bloks from Ritter he has them available. I am not a small block guy but have head from a very well known shop they need "some work" when you get them Bt I also know they believe everything needs some work as delivered anyway smile
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918672
09/24/15 11:22 AM
09/24/15 11:22 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
This is great news for Small Block guys IF the problems have been fixed or at least they're addressable now
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918683
09/24/15 11:38 AM
09/24/15 11:38 AM
USA
USA
Anyone have a number for Ritter?
Re: 420cid build with a new Ritter Aluminum Block [Re: hudsonhornet7x] #1918755
09/24/15 01:44 PM
09/24/15 01:44 PM
PA.
"Little"John
"Little"John
PA.
Here's his email.
http://www.hughesengines.com/Index/produ...mp;partid=25164
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 420cid build with a new Ritter Aluminum Block [Re: hudsonhornet7x] #1918756
09/24/15 01:44 PM
09/24/15 01:44 PM
fresno ca
mikeysmopars Offline
fresno ca
called Kevin at Hughes Engines yesterday about doing a ritter block and he said they have done 4 engines to date and have had no problems. He said they will support 1400 hp easily. just need to make clear what you want done from Ritter before they send the block to Hughes.
Founder and CEO of the Central Valley Mopar Drag Pack
