Page 2 of 12 1 2 3 4 11 12
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917803
09/23/15 12:23 AM
09/23/15 12:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
that's Andy's handywork.... he has some nice items.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917807
09/23/15 12:29 AM
09/23/15 12:29 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
While were looking at this side of the motor the oil pan will block off the oil return if you have an oil pan gasket lay it up there and you will see the oil return for the time tunnel is blocked off.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1917816
09/23/15 12:37 AM
09/23/15 12:37 AM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
Yes the oil pan will cover most of the original hole that was there that's why there is more of a slot there now. I have also drilled and tapped 4 1/2NPT holes right under the cam next to the back of the mains for oil drain back. I know if gets into the swinging assembly it will cost HP but for now getting the oil back to the pan is more important than windage loss.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917829
09/23/15 01:01 AM
09/23/15 01:01 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Are you bushing the lifters ?????will the lifter uncover the oil hole when its all the way at the bottom or all the way at the top.THIS is another big problem.... if so bushing the block is the easy fix... I would pressurize the water aND oil before I did anything..
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917840
09/23/15 01:18 AM
09/23/15 01:18 AM
Kansas, Topeka
Kansas, Topeka
At this point in time I am not planning on bushing the lifter bores he has moved the upper oil gallies up so it is just like a small Chevy, I told him that I wants the lifter bores under size so we could fit the lifters witch he did they were all .003" to.004" under sized. Right now the lifter clearance is .001" to .00012" I have assembled the whole motor several times and pressure tested the oil system to make sure that the oil doesn't go into the cooling jackets or in to the crankcase. I have also pressure tested the cooling jackets to 10 psi on both sides using my torque plate and the right side held 10 psi overnight and the left side was 9 psi in the morning it started at 10 psi so I don't know if the O-ring plugs leaked or head gasket or the porosity in the block. But I plan on checking the water system again after it is fully assembled. Thanks for all of the information.
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1917844
09/23/15 01:22 AM
09/23/15 01:22 AM
Kansas, Topeka
Kansas, Topeka
New oil galley positions.
oil gallies
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917847
09/23/15 01:27 AM
09/23/15 01:27 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
You don't have to bush the lifters but I'm thinking you'll need a taller than normal lifter so that when it's at the bottom the hole is not uncovered I've had both style blocks the one with the oil hole behind the lifter and the one with oil hole in the center of the lifter. If you measure from the base of the cam to the top of the oil hole that will tell you how tall of a lifter you will need
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917855
09/23/15 01:36 AM
09/23/15 01:36 AM
Kansas, Topeka
Kansas, Topeka
That's good information Thanks
When I was testing the oil system it didn't seam to uncover the oil galley's with all of the lifters heads and pushrods in place but I will defiantly check that when I test it again.
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1917857
09/23/15 01:38 AM
09/23/15 01:38 AM
Kansas, Topeka
Kansas, Topeka
cam and lifters
lifters
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917862
09/23/15 01:56 AM
09/23/15 01:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Are the front of those blocks the same as the 9.0 and 9.20 R3 blocks? (bolt pattern wise).
Re: 420cid build with a new Ritter Aluminum Block [Re: J_BODY] #1918001
09/23/15 12:40 PM
09/23/15 12:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
The ones I have seen all take the low deck cover however the block could use a tall deck cover if new holes are made.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918005
09/23/15 12:45 PM
09/23/15 12:45 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Originally Posted By 69 lawndart
cam and lifters
check every lifter to be sure that you are ok .they look low when they drill the galley from one side only the hole some times will wander of course. That is why other blocks are drilled from both directions and intersect one another
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1918067
09/23/15 02:10 PM
09/23/15 02:10 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I just had to drill and tap (2) new holes on my R3 block for a stock 360 timing cover to work. Not a big issue
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 420cid build with a new Ritter Aluminum Block [Re: pittsburghracer] #1918068
09/23/15 02:11 PM
09/23/15 02:11 PM
PA.
"Little"John
"Little"John
PA.
Kinda like the looks of this block and I hope all goes well.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918096
09/23/15 02:55 PM
09/23/15 02:55 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Now where are the xr2s.... I'd love to get my hands on a raw casting of one of those.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918102
09/23/15 03:04 PM
09/23/15 03:04 PM
dogdays Offline
dogdays  Offline
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918268
09/23/15 06:43 PM
09/23/15 06:43 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
Are those coolant passages in the deck correct? Something funny looking there.
Re: 420cid build with a new Ritter Aluminum Block [Re: HotRodDave] #1918293
09/23/15 07:19 PM
09/23/15 07:19 PM
Kansas, Topeka
Kansas, Topeka
Some of the cooling passages in the deck I have added. Kent designed this block to except the P5 head so you need to drill water passages for your style of head. I used a Felpro Gasket for the pattern.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918305
09/23/15 07:44 PM
09/23/15 07:44 PM
PA.
"Little"John
"Little"John
PA.
What brand of roller lifters are those. Thanks for starting this post.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 420cid build with a new Ritter Aluminum Block [Re: pittsburghracer] #1918313
09/23/15 08:01 PM
09/23/15 08:01 PM
Kansas, Topeka
Kansas, Topeka
No problem, thanks for all of the input. The lifters are Morel +.300 height and .200 intake offset .904 diameter.
