Re: 420cid build with a new Ritter Aluminum Block
[Re: 69 lawndart]
#1917547
09/22/15 06:19 PM
09/22/15 06:19 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Judging from the background there I would say this is going in a 4 speed car! Very Nice!
Be prepared for lots of questions about the block
Clark
68 Barracuda Formula S 340
[Re: 69 lawndart]
#1917568
09/22/15 06:45 PM
09/22/15 06:45 PM
Posts: 1,073 oregon
greendart408
oregon
Good luck on your build, I hope you have better luck than all the others that have tried to make those blocks work. The metal welded in the crank to balance it there is not a good idea. Everyone I have seen done that way over time come out. Not trying to be negative, trying to help..... Maybe it's not heavy metal welded in there, hard to see in that pic.
[Re: greendart408]
#1917587
09/22/15 07:09 PM
09/22/15 07:09 PM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
You are right, its not heavy metal he just needed to fill in a drill hole a few oz. I hope the block turns out, that's why I am posting here. Hopefully people will say the problems they have had with their blocks so I can try and solve the problems before I get it in the car. Thanks Mike
[Re: 69 lawndart]
#1917667
09/22/15 09:05 PM
09/22/15 09:05 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
[Re: justinp61]
#1917752
09/22/15 11:06 PM
09/22/15 11:06 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I hope that the new blocks. Are better than the old ones. Did he fix the rear main cap so the oil passage .would line up with the pump.i would love two see a pic with the oil pump gasket laying on the cap
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: AndyF]
#1917773
09/22/15 11:35 PM
09/22/15 11:35 PM
WHITEDART
bean town ....Ca
Looks killer. An engine like that deserves a billet timing chain cover! different bolt patterns
