Page 1 of 12 1 2 3 11 12
420cid build with a new Ritter Aluminum Block #1917531
09/22/15 05:31 PM
09/22/15 05:31 PM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
This is my first post here so hi to everyone.
I am working on a new 420 cid small block with a Ritter aluminum block. the heads will be RFD W9RP heads, crank is 3.875 stroke with 6.300" long Oliver rods. and Ross flat top pistons. Not sure if the pictures are attached.
Bottom end
1,3,5,7
gears
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917547
09/22/15 06:19 PM
09/22/15 06:19 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Judging from the background there I would say this is going in a 4 speed car! Very Nice!
Be prepared for lots of questions about the block
Clark
68 Barracuda Formula S 340
Re: 420cid build with a new Ritter Aluminum Block [Re: Bad340fish] #1917551
09/22/15 06:25 PM
09/22/15 06:25 PM
Kansas, Topeka
Kansas, Topeka
Yes sir, its going in the Dart with the 5 speed. The Cuda will keep the 468 in it. Question are not a problem.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917568
09/22/15 06:45 PM
09/22/15 06:45 PM
oregon
greendart408 Offline
oregon
Good luck on your build, I hope you have better luck than all the others that have tried to make those blocks work. The metal welded in the crank to balance it there is not a good idea. Everyone I have seen done that way over time come out. Not trying to be negative, trying to help.....
Maybe it's not heavy metal welded in there, hard to see in that pic.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917575
09/22/15 06:50 PM
09/22/15 06:50 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Needs to go in my Dart MC.
Re: 420cid build with a new Ritter Aluminum Block [Re: greendart408] #1917587
09/22/15 07:09 PM
09/22/15 07:09 PM
Kansas, Topeka
Kansas, Topeka
You are right, its not heavy metal he just needed to fill in a drill hole a few oz. I hope the block turns out, that's why I am posting here. Hopefully people will say the problems they have had with their blocks so I can try and solve the problems before I get it in the car.
Mike
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917589
09/22/15 07:14 PM
09/22/15 07:14 PM
oregon
oregon
Good luck with it, should be a fun piece.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917667
09/22/15 09:05 PM
09/22/15 09:05 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917668
09/22/15 09:06 PM
09/22/15 09:06 PM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
Welcome, looking forward to seeing the build.
I saw you in Cordova but did not have a chance to talk.
Really looking forward to seeing you back on Drag Week next year, I assume that is the plan.
Bill Lamb
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917674
09/22/15 09:16 PM
09/22/15 09:16 PM
Kansas, Topeka
Kansas, Topeka
At this point in time that is the plan, I saw you and was wanting to get over and talk to you and see what you have updated on the car. I hope to have this thing back in the car by the end of the year. That gives me all of next year to sort it out. I have talked to some of the guys that have had problems with these blocks and so far most of the major problems were fixed when I got the block. There have been a few small things but nothing major.
Mike
Re: 420cid build with a new Ritter Aluminum Block [Re: J_BODY] #1917676
09/22/15 09:18 PM
09/22/15 09:18 PM
Kansas, Topeka
Kansas, Topeka
Thanks I have been following that threat since it started.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917746
09/22/15 10:57 PM
09/22/15 10:57 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I can't comment on your bock but I will say your head guy is one of the best in the country. Everything Curtis works on runs hard. Keep us updated.
Re: 420cid build with a new Ritter Aluminum Block [Re: justinp61] #1917752
09/22/15 11:06 PM
09/22/15 11:06 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I hope that the new blocks. Are better than the old ones. Did he fix the rear main cap so the oil passage .would line up with the pump.i would love two see a pic with the oil pump gasket laying on the cap
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917761
09/22/15 11:16 PM
09/22/15 11:16 PM
AndyF Offline
AndyF  Offline
Looks killer. An engine like that deserves a billet timing chain cover!
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1917768
09/22/15 11:26 PM
09/22/15 11:26 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I had a talk with lawndart, smart & knowledgable man. Sounds like the main issues the earlier blocks had have been corrected. Hope to see good results on his build. Since there aren't any r3's around, I might spring for a aluminum one for my demon.
Re: 420cid build with a new Ritter Aluminum Block [Re: AndyF] #1917773
09/22/15 11:35 PM
09/22/15 11:35 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
different bolt patterns
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1917778
09/22/15 11:39 PM
09/22/15 11:39 PM
Kansas, Topeka
Kansas, Topeka
I will take a picture of the gasket sitting on the rear main, the oil hole in the main lines up with the block oil hole.
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1917792
09/23/15 12:09 AM
09/23/15 12:09 AM
Kansas, Topeka
Kansas, Topeka
No sir it does not line up. I took some pictures and will and will attempt to post them, its an easy fix now that I know about it I will put it in the mill and mill a nice slot to the oil pump outlet. Thank you for pointing this out.
Mike
Rear main with Gasket
Rear main without gasket
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1917796
09/23/15 12:15 AM
09/23/15 12:15 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
it would be pretty cool to know that there are two operating Ritter blocks in existence. I'm truly hoping for the best for you. Small block guys need this option to basically stay alive.
Re: 420cid build with a new Ritter Aluminum Block [Re: AndyF] #1917798
09/23/15 12:18 AM
09/23/15 12:18 AM
Kansas, Topeka
Kansas, Topeka
That's a nice timing cover who makes it?
