Page 9 of 11 < 1 2 7 8 9 10 11 >
#2113775 - 07/19/16 11:45 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
1967dartgt Offline
Loc: Hilltown Pa
I have seen pics on Facebook of it out cruising the street getting ready for drag week.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
#2114398 - 07/20/16 08:28 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
fishy340 Offline
Loc: LONG ISLAND
I wish we knew how things are going...thread kinda disappeared.
#2114426 - 07/20/16 09:05 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
J_BODY Offline
Loc: aZLiViN
Car that cool it should be a requirement for a weekly update! smile
#2114489 - 07/20/16 10:53 PM Re: 420cid build with a new Ritter Aluminum Block [Re: J_BODY]
pittsburghracer Offline
Slowride
Loc: PA.
I noticed around here that no news is bad news
1970 Duster
Edelbrock headed 408
6.143@110.89 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
6.001@113.27mph
9.44@138.23
Untitled by John Cadamore, on Flickr
#2114502 - 07/20/16 11:12 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
R3DART Offline
Loc: Edmonton Alberta, Canada
Fwiw mine is working well. I have put on about 400 street miles so far.
Need to get it to the track here ASAP.
#2114656 - 07/21/16 09:32 AM Re: 420cid build with a new Ritter Aluminum Block [Re: R3DART]
1967dartgt Offline
Loc: Hilltown Pa
How big of motor is yours? What kind of hp level are you running?
#2114917 - 07/21/16 02:39 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
ksj Offline
Loc: Topeka Kansas
Hes been busy with his daughters softball games,sons scouting activities and its been hot as heck around here.Plus the track prep at HPT has sucked this year.I know he made a couple of hits when the PowerTour was at the Kansas Speedway.I havent heard the results.
#2115706 - 07/22/16 05:15 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 1967dartgt]
R3DART Offline
It's 468ci, 360-1 heads, bullet solid roller, 12.54-1, 1050 dominator.
#2115890 - 07/22/16 09:28 PM Re: 420cid build with a new Ritter Aluminum Block [Re: ksj]
J_BODY Offline
Loc: aZLiViN
Originally Posted By ksj
Hes been busy with his daughters softball games...
laugh2.... that parked my ride for 4 years! (and I'd give anything for just one more year....)
hear you on the heat. been a miserable summer in the central us.
Edited by J_BODY (07/22/16 09:29 PM)
Edit Reason: hear.... not here :)
#2115895 - 07/22/16 09:39 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
ksj Offline
Loc: Topeka Kansas
He also took some time to put together a BB Chebbie motor for a friend of ours.Hes a busy guy.
#2116439 - 07/23/16 11:05 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
69 lawndart Offline
Loc: Kansas, Topeka
Sorry guys I have been really busy, I have over 2000 miles driving on the street and highway. I took the car to the Roadkill nights at Kansas Speed Way, it was called pit lane drags. I will say that this thing is WAY more motor than I expected. On the second pass I lost the cam sync and the timing went crazy. I fixed that and made a third pass after that pass it was down 15 to 20 psi oil pressure so I played it safe and pulled the motor to take a look at it. #3,#5 and #7 rod bearing were scuffed not spun, every thing else looks great, mains look like they just came out of the box cam bearing looked good, the worst cylinder on the leak down test was 3% hot. We polished the crank feed it a set of rod bearing and its back together and on the run stand, I hope to fire it tomorrow. I have up graded the oil pump to a Titan pump I have had on the shelf for a few years. I will try and do a better job about keeping you guys updated.
Edited by 69 lawndart (07/23/16 11:11 PM)
#2116447 - 07/23/16 11:23 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
rickraw Offline
Loc: Ambridge, Pa.
Any et?
#2116453 - 07/23/16 11:48 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
MoparBilly Online   content
Loc: Phoenix, AZ
Well then, the old combo was good for ten teens at a buck thirty-four. Mr. Crow has never been one for overstating anything either, so I'm looking for good stuff indeed!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
#2116467 - 07/24/16 12:53 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
ksj Offline
Loc: Topeka Kansas
No need to apologize. You have been busy.
#2116954 - 07/24/16 10:17 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
69 lawndart Offline
Loc: Kansas, Topeka
Update, it runs and all is good, the oil pressure is 50 to 60 hot idle with 10W-30 oil. The new pump is definitely moves more oil. I plan on warming it tomorrow evening and doing a leak down and compression test and cut the oil filter apart, if all looks good then back in the car.
#2117016 - 07/24/16 11:24 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
1967dartgt Offline
Loc: Hilltown Pa
So do you know why you got the rod bearings?
#2118732 - 07/26/16 10:25 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 1967dartgt]
69 lawndart Offline
Loc: Kansas, Topeka
I think it was a combination of things. Losing the cam sync made the timing fire where ever it wanted to, thus beating the rod bearings, none of them fit nice in the rods when I took it apart. And the fact that that on the third pass the new shifter locked between 2nd and 3rd gear sending it way high in the RPM, the high rev limit was turned off. (my fault) I don't blame the block in any way. The last thing is the oil pressure has been dropping about 10 psi above 6000 RPM, that's why we decided to change the pump. According to Titan oil pumps I was cavitating the pump at higher RPM.
#2118762 - 07/26/16 10:58 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
B3422W5 Offline
Loc: Portage,michigan
Is there a minimum amount of oil you need with those Titan pumps? Thought I read somewhere like 13 quarts or something, but wasn't a Mopar engine
69 Dart GTS, performance upgrades in progress
11.26@ 118.40 best so far. Stock 360 shortblock with eddie heads.
#2129135 - 08/09/16 10:19 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
69 lawndart Offline
Loc: Kansas, Topeka
Update, finally got time to put the motor back in the car and driving it. Took it into town this evening and gave the car a good bath an then went out on the highway for a 20 mile drive, temp was 177 to 180, oil pressure was 70 to 75 psi and hot idle oil pressure id 45 to 50 psi. oil is clean. plan on driving it to work tomorrow weather permitting. then I will cut the filter apart and take a look.
#2129168 - 08/09/16 11:02 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
Slowride
Loc: PA.
Great news. Thanks again for sharing this information
1970 Duster
6.143@110.89 mph
6.001@113.27mph
9.44@138.23
25,068 Registered Members
185,585 Topics
1968 Dart on CL
by RTSrunner
01/18/18 02:52 AM
spark plugs ?
by sixbbl 69
01/18/18 12:06 AM
A100 power steering
by 2002bluert
01/17/18 10:00 PM
W23 Recall Wheel Price
by 2002bluert
01/17/18 09:58 PM
