Page 7 of 12 1 2 5 6 7 8 9 11 12
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1961185
12/01/15 08:02 PM
12/01/15 08:02 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
It is in my opinion🎲🎲 the oil galley should have just broke through into the lifter .or done like a typical r3... not dead center
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1962254
12/03/15 04:17 AM
12/03/15 04:17 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Keep the updates coming. I'm interested in one if they work.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: 420cid build with a new Ritter Aluminum Block [Re: MR_P_BODY] #1962505
12/03/15 05:06 PM
12/03/15 05:06 PM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
I drilled and tapped holes in the bottom of the cam valley.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1963156
12/04/15 03:13 PM
12/04/15 03:13 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Kind of easy to see here why it would have drainback issues.
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1963200
12/04/15 04:11 PM
12/04/15 04:11 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Originally Posted By WHITEDART
Did you use a grooved lifter or bushin, so the oil could pass by 100% of the time. Because the oil galley is dead center of the lifter a groove someplace is necessary.. I used a grooved bushing. So that oil will pass by continuously
Are you saying that the galley drilling goes straight through the lifter bores? As in... The first lifter blocks oil to all the rest!?
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1963256
12/04/15 05:36 PM
12/04/15 05:36 PM
Kansas, Topeka
Kansas, Topeka
Yes sir it does go right through the center of the lifter bore. the lifters (Morell)I an using have a hole in the center so oil can pass through them.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1963464
12/05/15 12:02 AM
12/05/15 12:02 AM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
Welcome to MoParts, Mike! So glad to see you getting this new bullet ready for your awesome Dart. Can't waiting to hear it singing through the gears on Drag Week again. Best of luck to you!
I hope that third times a charm for me to get my 'Cuda to Drag Week in 2016. Had a lawn sprinkler Indy BB head put me down for 2015.
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1970147
12/15/15 02:03 PM
12/15/15 02:03 PM
Kansas, Topeka
Kansas, Topeka
Up date, After finding out that the lifter is blocking the oil flow down the lifter galley, That's why I have limited oil flow to the top end. I have dissembled the motor and we are in the process of installing lifter bushings with a slot in them for oil to pass through the lifter and oil the rest of the lifters. The oil that came out of the motor was clean no water in it. The bearing looked good except for one rod that had some stuff go through it.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1970232
12/15/15 04:25 PM
12/15/15 04:25 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I don't think a slotted bushing would be in your best interest you need a bushing that has a circular groove so the oil can pass by both sides of the lifter not through it. I will try to post a picture
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1970234
12/15/15 04:29 PM
12/15/15 04:29 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
The bushing on the left allows oil to pass by 100% of the time I think that's what you need that's what I had to do
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1970237
12/15/15 04:33 PM
12/15/15 04:33 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
You can ignore the up and down slot that's for a keyway lifter you just need a typical grooved lifter bushing unless you're running a keyed I had to go to a large lifter to correct the location. And angle... lifter timing would have not been correct if we did not fix that problem hopefully you don't have that issue... most people would never check...
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1970378
12/15/15 08:25 PM
12/15/15 08:25 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Valuable info WHITEDART.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1970497
12/15/15 11:03 PM
12/15/15 11:03 PM
Kansas, Topeka
Kansas, Topeka
Thanks for the input, I see what you are saying with the free flow around the bushing to keep the oil flowing to the rest of the lifters. I am running a Morell lifter with the .180 intake offset.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2029217
03/11/16 03:03 PM
03/11/16 03:03 PM
Kansas, Topeka
Kansas, Topeka
Up date the bushing are installed and honed to size. after a trip to the machine shop for a good cleaning then home to begin reassembly. Will keep you posted.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2029347
03/11/16 06:57 PM
03/11/16 06:57 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Looking good!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2029612
03/12/16 02:21 AM
03/12/16 02:21 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Can't wait to see it on dyno
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2029700
03/12/16 11:25 AM
03/12/16 11:25 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
nice work who did the machine work. Do you have a pic of both decks I would like to see if he made any changes
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2031641
03/15/16 01:57 PM
03/15/16 01:57 PM
Kansas, Topeka
Kansas, Topeka
The machine work was done by S&K Engine Specialists in Topeka KS.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2031657
03/15/16 02:25 PM
03/15/16 02:25 PM
dogdays Offline
dogdays  Offline
drool drool drool
R.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2033160
03/17/16 02:50 PM
03/17/16 02:50 PM
Kansas, Topeka
Kansas, Topeka
Update it runs, good oil supply to the top end, cold oil pressure is 70 to 80 psi and hot oil pressure is 35 to 40 psi,if you touch the throttle the oil pressure is 60 plus. No bad noises oil is clean.
