Re: 420cid build with a new Ritter Aluminum Block
[Re: Dragula]
#1941431
10/30/15 12:39 AM
10/30/15 12:39 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Two stupid questions.....What is the difference between the XR1 and the XR2 aluminum blocks?
And what heads are you guys typically running on these?
XR2=P7 heads XR1=W7,8,9 heads
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Dragula]
#1941490
10/30/15 02:13 AM
10/30/15 02:13 AM
Posts: 6,130 Melbourne , Australia
LA360
XR1 takes the wedge style LA series head
XR2 takes the Dodge P7 head. These blocks were designed primarily to run the P7 heads (As Kent as a very large stock pile of them)
Alan Jones
[Re: 69 lawndart]
#1948233
11/09/15 07:35 PM
11/09/15 07:35 PM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
Short block is assembled, At this point in time we are flowing the heads through the intake and throttle body, and with the headers. When that is done everything is ready to finish the long block. The next step is to run it on the test stand. Have a few small things to finish on the run stand. I will post the results and a video of start up and it running. Thanks for all of the input and interest. Mike
[Re: SpareParts]
#1948422
11/09/15 11:33 PM
11/09/15 11:33 PM
Posts: 437 south central pa
bdaz smblk
south central pa
So what's a guy use for a cam in an XR2 P7? You use a r5 cam and have the snout modified by lsm.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: 69 lawndart]
#1956241
11/23/15 01:10 AM
11/23/15 01:10 AM
1967dartgt
Hilltown Pa
Wow can't wait for results! You plan on dynoing it or just put in car when it comes off run stand?
[Re: 69 lawndart]
#1960855
12/01/15 12:37 PM
12/01/15 12:37 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Glad to hear that it is running! Is it in the car or on a run stand?
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Bad340fish]
#1960860
12/01/15 01:03 PM
12/01/15 01:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this block designed more for a dry sump than a wet sump being that you had to come up with drain backs... and as asked already... how is the quality of the alum and porosity(if any)
[Re: 69 lawndart]
#1961181
12/01/15 07:56 PM
12/01/15 07:56 PM
MR_P_BODY
Did you drill a couple of holes in the dist area(at the bottom) for your return oil.. I didnt recall seeing the return pics EDIT Thanks for the info and hope it goes well for ya and makes good power
[Re: 69 lawndart]
#1961182
12/01/15 07:56 PM
12/01/15 07:56 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Did you use a grooved lifter or bushin, so the oil could pass by 100% of the time. Because the oil galley is dead center of the lifter a groove someplace is necessary.. I used a grooved bushing. So that oil will pass by continuously
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
