Re: 420cid build with a new Ritter Aluminum Block
[Re: MoparBilly]
#2166331
10/02/16 10:03 AM
10/02/16 10:03 AM
Posts: 19,336 north of coder
moparx
Moparx, I borrowed the photos from Bob Brehm's facebook page. Bob is the best amateur automotive event photographer in the mid-west! Bob was a school friend of Doug, KSJ's brother, and he told me at Drag Week that KSJ's only redeeming quality was that he introduced Bob to 69 lawndart!
I have to agree KSJ has an innate knack of introducing cool people to other cool people!! While he is definitely not in that club, he serves as a kind of Social honey bee. well, regardless if you borrowed those pics, i'm glad you did billy. i have tried a couple of different ways to attach dog dish caps to different wheels with varying results always using the original "snap on" method of retention. my old, cloudy mind never gave it a thought to use a retention screw method, and i just looked at a cap laying around and concluded a nice flat head or button head 8 or 10-32 stainless screw would work perfect for what needs to be done and not be easily observed. so in the end, all you guys helped my old mind with a good kick start. and i am very appreciative of all you guys ! thanks again billy for getting this ball rolling and allowing me to obtain the info i was seeking !
[Re: 69 lawndart]
#2180611
10/23/16 12:17 AM
10/23/16 12:17 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Good to see some more laps on this.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 69 lawndart]
#2356022
08/18/17 01:17 PM
08/18/17 01:17 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Sounds like you're headed in the right direction. Keep us posted
[Re: 69 lawndart]
#2356071
08/18/17 03:03 PM
08/18/17 03:03 PM
Posts: 19,357 Las Vegas
Al_Alguire
Las Vegas
That is not in the owners possession apparently still at Ritters....
[Re: 69 lawndart]
#2428374
01/03/18 05:05 PM
01/03/18 05:05 PM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
I pulled it last Friday to look it over. It looks Ok, its not great and it not bad, on three of the rod bearing the coating looks like it flaked off on the top of the bearing. The main bearings look good, cam bearing are showing some wear but that's expected with the spring pressures and RPM I am running. Piston skirts looked good nothing to be worried about.
[Re: 69 lawndart]
#2428399
01/03/18 06:02 PM
01/03/18 06:02 PM
fast68plymouth
So. Burlington, Vt.
Latest up date, I pulled the motor out of the car it has about4300 miles on it with no problems. Right now it is sitting on a Dyno and we have made 11 pulls, the numbers are not that great but we will keep working on it. the oil pressure is great and it is giving us no sign of problems. Did you find any power with what you tried on the dyno? Is it up to your expectations, or will you be looking for more when it goes back together?
