Got a question...
Suppose:
->You are running a single electric 16" fan.
->The fan does not cover the radiator surface (31x19).
->There is simply not enough room for a shroud.
->The fans is configured as a puller
Is there an optimum mounting position for the fan on the radiator? As in, biased towards the inlet side or the outlet side. My gut feeling is biased toward the inlet to try to knock down the temp early, but that may not be the case. (the old melting ice quicker with cold water trick comes to mind)
Any ideas with any thermal dynamic info to back it up?
