904 KD bands
#191292
01/12/09 10:32 AM
01/12/09 10:32 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I'm going to be freshening up my 904 and also swapping the 4 disk drum to an A999 5 disk setup with associated parts.
Right now I have a narrow red lined flex band (I think with a 4.2 lever) and it seemed to work fine but I am going to be putting some more power thru it this upcoming year and don't know if I should upgrade to a solid or other friction material.
I know with the 5 disk drum, I could now use a wider A999 band but I was told to not use it since the lugs are offset and it causes the band to not apply straight.
Any thoughts??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 904 KD bands
[Re: CJK440]
#191293
01/12/09 02:45 PM
01/12/09 02:45 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I use a lot of the wider bands never seen a problem
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 904 KD bands
[Re: dartman366]
#191300
01/12/09 09:18 PM
01/12/09 09:18 PM
CJK440
Ansonia, CT
90% race. I might take it to the local cruise or off to the parts store downtown but thats it.
Re: 904 KD bands
[Re: CJK440]
#191301
01/12/09 11:34 PM
01/12/09 11:34 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I think with the tire and specific racing you do, that easing the 1/2 shift might be a good thing. Just my opinion, but I'd definately keep it in mind.
Re: 904 KD bands
[Re: moper]
#191302
01/13/09 10:30 AM
01/13/09 10:30 AM
CJK440
Ansonia, CT
Thats what I am concerned about. The narrow red band was fine with my latest combo, a chirp on the track but that was it. I'm afraid kevlar might grab too harshly, perhaps a wide red band will hold more but not grab as quick. I just heard that the wide band can apply uneven due to the offset lugs so I figured I'd inquire.
I see three widths of band offered. 1.375 which is what I assume I have (std 4 clutch drum) and a 1.610 and 1.750.
Whats the difference in the 2 wider ones other than the width of course.
Re: 904 KD bands
[Re: CJK440]
#191303
01/13/09 02:22 PM
01/13/09 02:22 PM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
Chris I've been told Kevlar is fine for the rear band because nothing is spinning when it's applied , it can be a problem in the front location over time because it's stopping a spinning drum .
Re: 904 KD bands
[Re: JohnRR]
#191304
01/19/09 10:15 AM
01/19/09 10:15 AM
CJK440
Ansonia, CT
I am using a Cheetah VB with no low band apply so that band only works in Rev.
I did tear the tranny apart and noticed the KD band was discolored all the way around but biased to one side only. It's a flex band. This was with perhaps 50 passes and 300 street miles.
With more HP I'm sure I don't want to reuse the narrow red but will a wide red be enough improvement or should I try Kevlar?? More surface area with the wide red but won't it have less apply pressure for a given area??
Another 904 question but not band related...
The rear clutch pack, the one with the 4 thin non grooved clutches isn't a shifting clutch. Those things look brand new, no reason to change them this go around is there??
Re: 904 KD bands
[Re: CJK440]
#191306
01/19/09 08:42 PM
01/19/09 08:42 PM
dusturbd340W5
Kissimmee Fl.
heat and slippage and its common for me to see the flex bands burnt more to one side like that I always assume its the fact that it is a flex band and dont apply even.
