Fan shroud mounted to Griffin Exact fit #1911233
09/12/15 07:47 PM
09/12/15 07:47 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
I am trying to mount my factory fan shroud to a Griffin #5-00004 Exact Fit Radiator. Has anyone done this and how did you mount it? Pictures would help alot if you have them.
Re: Fan shroud mounted to Griffin Exact fit [Re: RBSat66] #1911255
09/12/15 08:26 PM
09/12/15 08:26 PM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
here's my Griffin and factory 26" shroud. I just bought stainless bolts that fit the radiator holes.
Re: Fan shroud mounted to Griffin Exact fit [Re: 70BigBlockSE] #1911459
09/13/15 02:13 AM
09/13/15 02:13 AM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
Mine has a flange on both front and back of the radiator, did you have to cut the flange?
Re: Fan shroud mounted to Griffin Exact fit [Re: RBSat66] #1911610
09/13/15 12:53 PM
09/13/15 12:53 PM
Jacksonville Fl
Jacksonville Fl
didn't have to change anything on the radiator, just buy hardware because factory hardware was different. On the shroud I had to remove about 1/4" for the lower radiator hose
Re: Fan shroud mounted to Griffin Exact fit [Re: 70BigBlockSE] #1911701
09/13/15 03:28 PM
09/13/15 03:28 PM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
radiator/shroud mounting style was changed in 70. I bought a new mp shroud for my exact fit 69 radiator with the flange.it fit great
Re: Fan shroud mounted to Griffin Exact fit [Re: RBSat66] #1911807
09/13/15 08:05 PM
09/13/15 08:05 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
It looks like you have a #5-00058 Radiator. I have com to realize I have a dodge fan shroud. Have the right one ordered now. Thanks for your response, it helped lead me to the answer.
Re: Fan shroud mounted to Griffin Exact fit [Re: ragin sonny] #1911808
09/13/15 08:07 PM
09/13/15 08:07 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
Yours have the 5 bolt mounting holes for the shroud I'll bet.
Re: Fan shroud mounted to Griffin Exact fit [Re: RBSat66] #1911913
09/13/15 10:43 PM
09/13/15 10:43 PM
Jacksonville Fl
Jacksonville Fl
I do have the 5-70058 Griffin
Re: Fan shroud mounted to Griffin Exact fit [Re: RBSat66] #1911988
09/14/15 12:09 AM
09/14/15 12:09 AM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
sat 66, I've got the 5-70004.yea it's got 5 studs.my old shroud was cracked so I bought a mp 2785434 shroud.it fit well
Re: Fan shroud mounted to Griffin Exact fit [Re: ragin sonny] #1912580
09/14/15 10:57 PM
09/14/15 10:57 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
Thanks Ragin Sonny, Believe it or not Summit Racing in Tallmadge had the MP2785434 Fan Shroud in stock for $87.97. now on to installing it.
