Re: compression test numbers
[Re: buildanother]
#1911032
09/12/15 11:43 AM
09/12/15 11:43 AM
Posts: 5,161 CT
GTX MATT
CT
The starting issue is not going to have to do with the compression difference. I would get it running first and recheck. I agree with the post above, mostly because its highly unlikely any 383 without pop-up pistons is going to make 205 PSI. 150-155 is healthy though.
Check your spark, and that its getting gas. Is the fuel fresh? And did you change the filter?
[Re: GTX MATT]
#1911036
09/12/15 11:53 AM
09/12/15 11:53 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
What he said. Your no-start issue and #8 cylinder observation are unrelated. Get it running and then come back to the cylinder pressure thing. It might just go away.
[Re: BSB67]
#1911056
09/12/15 12:49 PM
09/12/15 12:49 PM
RapidRobert
among other things mentioned (oil change/fresh gas etc) I would turn the dampener with a 1&1/4" socket breaker bar till the the rotor is at the #8 dist cap terminal (magnet dead even with the tooth) then pull the dist/intergear & preoil then turn the crank 3/4 turn CW till the dampener slit is at TDC on the tab & preoil the other bank (I forget which goes to which but no big deal)
[Re: frank]
#1911078
09/12/15 01:59 PM
09/12/15 01:59 PM
Posts: 4,848 Memphis
HemiRick
Memphis
All it needs to start is fuel, compression and spark at the right time....which of these are you missing? The compression is fine as far starting goes.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: frank]
#1911116
09/12/15 03:34 PM
09/12/15 03:34 PM
BSB67
Prospect, PA
Or a collapsed lifter, or.....
Get it started
