Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1911530
09/13/15 10:17 AM
09/13/15 10:17 AM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
The Nason we sprayed looked closer to the darker B7 but the Sherman looked more like B5. A guy up the road from me restores cars also and he uses Nason for base but I think he uses a more expensive clear.
Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1912145
09/14/15 12:12 PM
09/14/15 12:12 PM
pa.
dan9 Offline
dan9  Offline
pa.
I just replaced the rear bumper and repaired the quarter panel on our GMC Envoy. It is a reddish maroon. My part store has a brand called Cromax. He asked me if I wanted the cheaper or more expensive line. I asked what the difference was. He said the more expensive was guaranteed to match. On this vehicle it didn't really matter but it was the best paint I have ever used and it did spot-in perfectly. As in painting and golf sometimes it's not the arrows, it's the indians.
Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1912188
09/14/15 01:10 PM
09/14/15 01:10 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
As other posts have mentioned its more in the prep work than anything. Just painting as a hobbyist I have always used Chromobase and Nason products just because thats what I was first introduced to and became comfortable using. Chromobase products got very pricey awhile back so I switched to using Nason and have had very good results with the last couple of cars I painted with it. The one thing I have noticed with Nason paint and primer is that it takes alot more to cover than the with the Chromobase line(some of it may have just been the color I was using), but I like the Nason clearcoats, I didnt notice a whole lot of difference in those. In fact the Nason clear seemed to lay down better than the more expensive ones I have used. Just my 2 cents...
Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1912524
09/14/15 10:13 PM
09/14/15 10:13 PM
KY
Telvis Offline
Telvis  Offline
KY
Omni will not cover as well l and you will use significantly more base coat to get good coverage. I use PPG and have painted with Omni. It's usually on something that will be sold quickly, You can get good results with it but it doesn't hold up to the elements very well.
I like Deltron DBC. It is easy to match if you need to make a repair later and covers well. I like the PPG 4000 clear. It lays down nice and polishes out well. As with most things, you will find opinions all over the place. There are other paints that will work well. I have always used PPG so thats what I am comfortable with. Like others have said, the paint is only a small part of the refinishing job.
You can buy the worlds most expensive paint and If your bodywork and prep are poor it will look like crap.
That's King Weenie to you!
Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1912553
09/14/15 10:35 PM
09/14/15 10:35 PM
Oreland Pa
clonedshaker+6 Offline
Oreland Pa
i painted my car base clear in Deltron DBC, its GB7 the 71 color, I have a friend that is a PPG rep and he found the formula for me. he said that he could not find it in any of the computers and only found it in a book and I believe it was under some special vehicle color, I guess since production numbers where low for the color.
71 challenger 440 sixpack shaker *CLONE* (71challenger 440+6 shaker clone FAST/my HS grad present)
03 mustang Mach 1 (daily driver)
11.35 @ 121.5 4 SPEED on F60-15s w/ 6/32 tread
Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1912617
09/14/15 11:24 PM
09/14/15 11:24 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Ok guys here is my 2 cents worth on paint. First, I am talking about our babies here. Budget paints have their place on an older commuter car that has seen better days, but not on any full on restoration.
I used to be a painter at a body shop, and have been around body shops and collision repair in some capacity or another as a professional for 30 years. With paint, much like anything else, you get about what you pay for. There is no way that I would spend 4k on a new engine and then put quaker state or bulk oil in it. Same thing with paint. All the work is in the prep. Why cover all that work with a budget line paint? There is a reason they are cheaper- fewer mixing colors mean poorer matches, lower solids mean more coats/time in the booth/ and materials on the car, and metallics are cheaper and not as sharp.
The best products for my money are PPG DBC base coat with PPG Global clear. DBC base system offers the best color match of any out there. True it may not matter when you are painting a car all over, but if you drive it at all it will need work again somewhere down the line. DBC line base covers better, so it means less coats, which means less material and less paint mileage, and less time in the booth (all good). Global clear is their highest level clear and was made to meet OEM specs for high end European imports. Glasurit and Sikkens are similar quality, but do not have the same color match capability and are harder to find.
I have sprayed Chromabase and Centari (dupont), Nason enamel, acrylic enamel, and base clear, Omni (PPG's budget line), Sikkens, Acme Probase, Western, Sherwin Williams (yes they do auto paint) and I can't remember what else. I would take the PPG DBC line and the Global clear over any of them. It will last longer
One exception. If I were painting a truck that was to be used as a truck and not a show car, I would use Dupont Imron 6000 base clear. Imron is what is used by heavy equipment manufacturers on semis, buses, airliners, etc. Something about Imron's chemical compounds makes it harden like no other paint and it has 10 times the scratch resistance of any other automotive paint I have used. You can spray this stuff and forget it. Left outside for 10 years with no care it will still look the same as when it was sprayed, assuming you just washed the car.
This is not meant in any way to offend anyone or come across as a know it all. Every painter has their own methods and preferred products. If you used something else that you are happy with, that is all that matters. Some of the differences in appearance between products would be difficult to discern for most, unless you had two cars side by side. Some other differences would only begin to show a couple of years after the paint job.
We are all car guys. Most of us know someone who works in a body shop. If you can get them to call in your paint order under the shop's name, and have them put it on a cash ticket, you can go pick it up pay cash and usually get a 30% or so discount off of the retail price. This makes high end not much more expensive than the retail price for the budget line stuff.
Hope this helps someone.
Re: Paint, paint, paint! Which to choose? [Re: mgoblue9798] #1912671
09/14/15 11:55 PM
09/14/15 11:55 PM
eastern,Ky
eastern,Ky
I appreciate the help. Wish I could find a rep that could find me a formula for 1970 B7 in the Deltron.
Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1912690
09/15/15 12:12 AM
09/15/15 12:12 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
PPG number for b7 blue is 2020. If they don't have a formula for modern basecoat under that number, clonedshaker+6's post above mine say he just painted his and got someone at PPG to get the formula. You might ask him to take a pic of his paint can, as they put the mixing formula on a label on it a lot of times.
Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1912712
09/15/15 12:37 AM
09/15/15 12:37 AM
eastern,Ky
eastern,Ky
The 71 GB7 is darker than the 70 B7.
Re: Paint, paint, paint! Which to choose? [Re: 70RT Charger] #1915727
09/19/15 04:24 PM
09/19/15 04:24 PM
O
OLD318 Offline
OLD318  Offline
O
From what I remember, PPG makes the Deltron 2K paint in the base clear for B3 (2018) and B5 (2019) 1970 color codes - but never for the B7...(2020).
They will make it in single stage and delstar enamel and lacquer.
FWIW, The guy that mixes the PPG paint around here said there is no recipe for B7 (2020) in base/clear because the toners needed for it were not created in the base/clear line...
I've only sprayed PPG deltron 2K
Check Other brands Dupont, Glasurit, Sherwin Williams etc to see if they provide it...
Best of luck to you
