Re: Building headers and getting ready for the season.
[Re: 4404dart]
#191081
01/11/09 11:36 PM
01/11/09 11:36 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Great Job,
I believe I will have to do the same thing. I have 2" ProParts, but will be running a 499 and believe I need a bigger primary.
I am a good fabricator, but never tried to build headers. Not even sure where to start!
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: GTSDave]
#191082
01/11/09 11:45 PM
01/11/09 11:45 PM
Posts: 5,617 long island NY
Ari440
long island NY
VERY NICE where did you get the flanges , pipes and collecters from
1.39 9.85 - 137 mph
[Re: BobsProFab]
#191084
01/12/09 12:29 AM
01/12/09 12:29 AM
Posts: 4,662 On the parachute mount
n20mstr
Very nice...looks real professional,
Please do me a favor, unbolt that Milodon oil filter adapter off the pump, tap the two holes and plumb yourself a remote filter...PLEASE get rid of that accident waiting to happen oil filter arangement while the motor is apart....
....BAD A$$ STREET CAR.....
[Re: 4404dart]
#191090
01/12/09 12:54 AM
01/12/09 12:54 AM
n20mstr
Thanks Tony! I have a Indy filter adaptor that has the fittings for a remote filter, but I can't figure out where to mount it? The vacuum pump, and puke tank are on that side, as well as the overflow for the radiator. Is it the oil pump to adaptor that your worried about? This adaptor is a billet part with O rings(can't remember the co?) Is it just having the filter in this stock location? Thanks for the tips over the years, keep em coming.
Well if its an Indy adapter with orings then your good, i thought it was a Milidon, a very poor design that has only two bolts spread very far away from the two holes, and a thick paper gasket that is notorious for blowing out and causing crashes etc.... Updates look good, get that car to a sea-level track and you have a very bad a$$ Mopar there It should run very well...
[Re: 4404dart]
#191092
01/12/09 02:03 AM
01/12/09 02:03 AM
GTSDave
GTSDave, and Ari440, I got everything from Stahl headers. J bends and L bends are your best bets. You don't need too many U bends, or straight sections, you'll have enough straight tubes left over. Think it out, and get a helper. I could of used a extra set of hands. Thanks.
Thanks,
Took the week off to try and finish the last patches to the floor pans, and tubbs. Then start stripping it and prepping for paint.
Hope to get in some long days this week with the kids in school and the wife at work, should give me plenty of time to get things done.
Don't want to put in the race engine until the engine bay is painted. I have a mock up engine in it right now but it has 906 heads, and the race engine has SR's on it, soon to be changed out for 440-1's. So much work....So little time!
I really like the way you did yours. Mine will be a bear because I will be running NSS and must keep stock steering. To further complicate things I am running a Jerico with manual clutch linkage (Per Rules.) Makes my head spin just thinking about how much of a bear it will be to build headers for this car. Almost wish there was someone local I could drop it off to and have them done.
-Dave
[Re: 4404dart]
#191093
01/12/09 07:39 AM
01/12/09 07:39 AM
Posts: 1,229 In The Hills
jughed
In The Hills
very nice job on the headers!!! where did you get those flanges?? i had headers made that are very similar to yours, they're also 2 1/4, 4" collectors. i have a NA 540, with future plans (pipe dream) for an F2.
[Re: jughed]
#191095
01/12/09 07:53 AM
01/12/09 07:53 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Those headers look really nice. You would think though with all the parts to make big Mopars now someone would come out with a bigger header. Keep up the good work!
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
