Big block 6 or 8 bolt crank? #191074
01/11/09 11:12 PM
01/11/09 11:12 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
which do you big block guys use more? 6 or 8 bolt crank? is there really a benefit?
I have an 8 bolt myself and was just wondering
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Big block 6 or 8 bolt crank? [Re: RylisPro] #191075
01/11/09 11:27 PM
01/11/09 11:27 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Being a stick guy I went with the six bolt for my new stroker just because my flywheels are six bolt
Gus
64 Plymouth Savoy
Dana 60
Re: Big block 6 or 8 bolt crank? [Re: RylisPro] #191076
01/12/09 12:56 AM
01/12/09 12:56 AM
I've used both in my Duster street motor with the 727, I don't see a big difference on the automatic using a flex plate On a stick shift car the 8 bolts are 1/2 diameter instead of the 7/16 six bolt size which will by a better clamping force on the flywheel
