Page 5 of 6 1 2 3 4 5 6
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375271
09/19/13 11:33 AM
09/19/13 11:33 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
315/35/20 tire-its too small...
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375272
09/19/13 11:38 AM
09/19/13 11:38 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
left rear view of the same tire
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375273
09/19/13 11:40 AM
09/19/13 11:40 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
This is one of my new favorite pictures
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375274
09/19/13 11:45 AM
09/19/13 11:45 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Right wheel tub and frame rails
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375275
09/19/13 11:48 AM
09/19/13 11:48 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Right rear tub from below
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375276
09/19/13 11:49 AM
09/19/13 11:49 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
driver side rear tub from the inside
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375277
09/19/13 11:51 AM
09/19/13 11:51 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Passenger rear tub from the inside.
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375278
09/20/13 04:06 AM
09/20/13 04:06 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Thanks for posting, I love checking the project section.
I can't afford this. mark
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1909692
09/10/15 01:45 AM
09/10/15 01:45 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
My wheels finally shows up!!
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1909694
09/10/15 01:47 AM
09/10/15 01:47 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
And another
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1909775
09/10/15 09:50 AM
09/10/15 09:50 AM
Maryland
K
Keepat Offline
Keepat  Offline
K
Maryland
Wheels look awesome! They will look great with B5 blue!
Good luck with your build
Pat
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1910035
09/10/15 05:08 PM
09/10/15 05:08 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Oh man, those are pretty.
I too think they will look great with B5!
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: Sneke_Eyez] #1911891
09/13/15 10:16 PM
09/13/15 10:16 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
Be sure to check that your rear side marker lights will fit, Check that the socket will fit! I thought mine would work until the car is all painted and I am putting it together.
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: sbhpcb] #1914338
09/17/15 11:13 AM
09/17/15 11:13 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Thank you for the tip-I appreciate it. That would be a pain to figure out later! I plan to delete the side marker lights.
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1924505
10/02/15 10:25 PM
10/02/15 10:25 PM
KY USA
E
E-Body Products Offline
E
KY USA
The car looks so good!!! Awesome project.
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1994638
01/20/16 02:06 AM
01/20/16 02:06 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Things are back on track. Matt is now working for himself full time again so things should happen fast. The front frame rails are on their way out. The rails don't have any holes but I want to pull the front suspension up into the car. Once I could see inside I was glad they are going...
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1994641
01/20/16 02:09 AM
01/20/16 02:09 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
New front rails
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1994646
01/20/16 02:16 AM
01/20/16 02:16 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Plus....I picked this up today at the UPS dock....powdercoated Strange 60 with 4.10 S-track limited slip and upgraded axles. Has late Ford ends so there are lots of brake options. I also ordered an F body housing so which has extra metal/tapped holes to support a torque arm.
[img]https://i.imgur.com/InSLizN.jpg?1[/img]
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: 70B5Cuda] #1995014
01/20/16 05:09 PM
01/20/16 05:09 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Looking good ... The 2 in drop in the front frame rails , is that gonna effect the height of the engine in the car?Hence you think it might hit the hood or what is your plans..I thought about the same mod in mine but decided against it for that reason... Awesome build BTW
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed [Re: johnscudashop] #1995089
01/20/16 06:52 PM
01/20/16 06:52 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
It will raise the intake into the hood but am planning to use a bubble scoop similar to the scoop found on the 2006-2010 Charger SRT8s. Also, I might be able to shorten the engine by going with a roots super charger.
