7&1/4 axle removal Q #1906727
09/05/15 05:19 AM
09/05/15 05:19 AM
RapidRobert Offline OP
Do these axles have a C clip or anything on the inside splined ends that needs to be undone first? thank you for your time
Re: 7&1/4 axle removal Q [Re: RapidRobert] #1906767
09/05/15 09:58 AM
09/05/15 09:58 AM
moparx Offline
moparx  Offline
i don't believe so. and just to confirm, i looked in my 69 FSM, and nothing was mentioned about removing the rear cover to remove the axles to change bearings. i also looked at the exploded view and couldn't see any inside axle retainer clips. as the view was small, i even used my "cheaters", but couldn't see any. hope this helps.
beer
Re: 7&1/4 axle removal Q [Re: RapidRobert] #1906791
09/05/15 11:01 AM
09/05/15 11:01 AM
md
mopars4ever Offline
mopars4ever  Offline
md
It should have bearing retainers on each end of the housing. It`s not like the 8 1/4 c clip IIRC.
Re: 7&1/4 axle removal Q [Re: mopars4ever] #1906844
09/05/15 12:43 PM
09/05/15 12:43 PM
Helps tremendously. I just put the cover on & filled er up & did not want to have to go back in there. thanks guys!
