Re: demensions of an extended cab 92-96 Dakota
[Re: poorboy]
#1886734
08/07/15 01:14 AM
08/07/15 01:14 AM
Posts: 16,810 Between Houston & Galveston TX
SattyNoCar
If no one steps up, I'll get you some measurements this weekend. (mine's a '93)
John
[Re: poorboy]
#1899582
08/26/15 03:33 AM
08/26/15 03:33 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
23.25" from back of cab to rear edge of door on the '94 and '96 I have sitting here.
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: Cheeto]
#1906562
09/04/15 10:35 PM
09/04/15 10:35 PM
moparpollack
Lil Herman
Lil Herman
85086
I did a short bed Dakota for my Plymouth Pick Up and it worked out great. A long bed or extended cab would work but the bed would need to be extended.
[Re: poorboy]
#1909024
09/09/15 02:09 AM
09/09/15 02:09 AM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I have a 91 long box, standard cab Dakota, 2 wheel drive truck as a doner. The 47 is a cab with doors, nose, hood, and box sides. I also have a pair of big truck front fenders. The 47 cab is about 5" shorter (and several inches more narrow) then the standard Dakota cab, at the center.
At this point, I'm hoping to pull the Dakota cab off the frame soon, then I will set the 47 Cab on the frame to make a decision. I am contemplating stretching the 47 cab 12" to accommodate my 260 lbs, 6'1", old, not so flexible body. The cab will probably be channeled low enough to cover the frame. I can split the cab right behind the back edge of the doors, and add my 12" there. I will probably add a quarter window to the side panels. I will split the roof at the crown and add the 12" at the highest point in the roof line. The Dakota extended cab is 19" longer then the standard cab, I don't want to add 19" to the 47 cab, so I will likely fabricate new floor pans rather then to try to adapt Dakota floor pans.
the box sides I have for the 47 truck, are 6 1/2' sides. I will likely cut the Dakota box sides off, and shorten the box floor to fit the 47 sides. I would like the 47 box to be wide enough to lay a 48" wide piece of plywood flat on the floor, the Dakota box floor will work, but I will need to add a piece in both sides of about 2" to the floor where the Dakota wheel wells were. I don't have a box front or a tailgate for the 47 box, so I will probably trim & reuse the Dakota box front panel and fabricate a tailgate. Depending on how things go, much of this may be done by next spring.
I will probably buy a truck for the drive train, Mopar of course. It will be pretty tame by most of your standards, it will be driven year around, and reliability with decent gas mileage is more important the going fast. Gene
