Intake Manifold Calculations #190611
01/11/09 04:57 PM
01/11/09 04:57 PM
Alberta Canada
StrokerAspen Offline OP
Alberta Canada
Has anyone made sheet metal intakes here before? Who are you using for your calculations? I have found some books on Amazon I was thinking of buying, but none of them are very current books. I have looked at the intake calculators on Wallace Racing too. Any thoughts?
Thanks!
-Kenny
Re: Intake Manifold Calculations [Re: StrokerAspen] #190612
01/11/09 05:39 PM
01/11/09 05:39 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Pipemax. maxracesoftware.com
Re: Intake Manifold Calculations [Re: StrokerAspen] #190613
01/11/09 05:39 PM
01/11/09 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've built several intakes, but the data I got was
from multiple sources, the one source was from the
internet... and I lost it when my other lap top got
filled up with some soup
I will tell you to make the plenum large... its
much easier to fill it in. I like to make the runner
the same volume as the cylinder. The thing is, is
the length for your engine, the taper is what I use
for the volume
Re: Intake Manifold Calculations [Re: MR_P_BODY] #190614
01/11/09 10:39 PM
01/11/09 10:39 PM
Alberta Canada
Alberta Canada
Alright, sounds good. Thanks!
