Crank bolt/flexplate. #190558
01/11/09 04:03 PM
01/11/09 04:03 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Anyone give me the bolt size?.........Callies 8 bolt crank , seems the stock bolts i got are too small , just ready to drop the motor back in & realised the bolts are different than a 6 bolt crank.
Re: Crank bolt/flexplate. [Re: 602heavy] #190559
01/11/09 05:45 PM
01/11/09 05:45 PM
The six bolt crank is smaller bolts..The eight bolt hemi bolts is what you need..Jegs has mopar and ARP sets..They are not cheap...$40-50 bucks..
Re: Crank bolt/flexplate. [Re: 602heavy] #190560
01/11/09 06:55 PM
01/11/09 06:55 PM
NC
440Jim Offline
440Jim  Offline
NC
The 6-bolt cranks use 7/16, the 8-bolt cranks use 1/2-20
Re: Crank bolt/flexplate. [Re: 440Jim] #190561
01/11/09 07:41 PM
01/11/09 07:41 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Thanks , will pick some up.
Re: Crank bolt/flexplate. [Re: 602heavy] #190562
01/11/09 07:52 PM
01/11/09 07:52 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Be careful,get the thin head Mopar bolts if you can.Standard bolts and even ARPs can hit on the converter and will cause it to keep loosening up and also wear into the converter face.
Re: Crank bolt/flexplate. [Re: B G Racing] #190563
01/11/09 08:37 PM
01/11/09 08:37 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Re: Crank bolt/flexplate. [Re: 602heavy] #190564
01/11/09 09:54 PM
01/11/09 09:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have heard of racers useing regular grade 8 bolts and grinding the heads down to clear the back of the converter, they do need to be thinner than the stock thickness on regular bolts how much I don't know
