Re: 69 Hemi vacuum advance unit
[Re: 62maxwgn]
#1905308
09/02/15 10:37 PM
09/02/15 10:37 PM
Posts: 45 Georgia
1969383S
Georgia
Outward wise his looks like the one on the distributor on the right. But internally it looks like none pictured. It has a square internal shape I am not familiar with.
His car is a "Very" early production 69 that has many 68 attributes. Quite awesome it is! Are there other units liked described?
Gerald
[Re: 1969383S]
#1905554
09/03/15 10:27 AM
09/03/15 10:27 AM
robertop
His car is a "Very" early production 69 that has many 68 attributes. Quite awesome it is! Are there other units liked described? Well, here is somebody that knows my car as well as me! I am sure I know who you are, because only two or three guys have seen my original distributor, which is indeed the one on the right. The vacuum unit had a broken diaphram, so I opened it up, thought I fixed it, soldered it back together, and tried to replate it, but with bad results. In the past I looked for another vacuum unit on ebay with no success, however yesterday I tried again and I found the right one for my engine and distributor number too, so for now I am happy. We'll see when I get the part, an NOS 'new' unit. Thank you all for your answer, keep your fingers crossed!
[Re: 62maxwgn]
#1905780
09/03/15 04:50 PM
09/03/15 04:50 PM
robertop
To satisfy my curiosity,how did you solder it back together being the front part is cast aluminum and the back stamped steel ? Repairing them is no problem but thats not the way it is done. My vacuum did not work because the little arm had separated from the diaphragm. I put the thing on a lathe and, with a fine cutting tool, cut on the outer half of the steel housing near the edge of the circumference until the two halves had split. After repairing the diaphragm I soldered back the split halves all around. I found later that my repair did not hold and the arm refuses to work, and I don't want to mess with it again, especially if a new unit is available on Ebay. All I can say is: I tried! By the way,the front part I'm sure it's made of a zinc casting, not of aluminum; I have to say that as a retired metallurgist....Sorry!
[Re: robertop]
#1906023
09/03/15 11:50 PM
09/03/15 11:50 PM
Posts: 45 Georgia
1969383S
Georgia
Roberto
What is the square piece I have seen over the linkage arm that connects to the breaker plate?
Is that something you just had over it for attempted repair work?
Gerald
[Re: 1969383S]
#1906207
09/04/15 11:02 AM
09/04/15 11:02 AM
robertop
Roberto
Is that something you just had over it for attempted repair work? While my car was being painted I took all the front suspension parts for refinishing, repair, or replacing as needed. I never gave them back, so when the car was delivered to me my painter took a piece of angle iron to tie together the front wheels so tha car could be safery moved into my garage. That piece is still attached today, I must say, but it will be removed soon. Hope!
[Re: 2JcodeChargers]
#1906634
09/05/15 12:27 AM
09/05/15 12:27 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
To satisfy my curiosity,how did you solder it back together being the front part is cast aluminum and the back stamped steel ? Repairing them is no problem but thats not the way it is done. "Repairing them is no problem" How are these Prestolite vacuum advance units restored? Mine needs it. I thought they were not fixable? Check your PM's
