Page 4 of 4 1 2 3 4
Re: Seats, Steering Wheel, and Seat Belt Options... [Re: MuuMuu101] #1904459
09/01/15 09:58 PM
09/01/15 09:58 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
\Could you post a link to the ones you bought? I ordered some from XV a few months ago and they never showed up.
A new iron curtain drawn across the 49th parallel
Re: Seats, Steering Wheel, and Seat Belt Options... [Re: MuuMuu101] #1904516
09/01/15 11:00 PM
09/01/15 11:00 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
I installed a set of Corbeau GTS II's in my Charger. Found a "like new" set on Craigslist, then had them recovered in white vinyl to match the stock upholstery pattern.
MUCH better than the stock buckets which had zero support. Also used Corbeau's seat tracks, which I had to lower a bit. Seems they have since redesigned them to sit lower. It appeared I had the taller variety, after chopping an inch out of them they fit much better.
Also have a Grant wheel, just added a Mopar horn button. Nice leather grip. (Pic taken before seat swap.)
Re: Seats, Steering Wheel, and Seat Belt Options... [Re: MuuMuu101] #1904545
09/01/15 11:16 PM
09/01/15 11:16 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
That looks just awesome Bill .Beautiful interior work.
Re: Seats, Steering Wheel, and Seat Belt Options... [Re: MuuMuu101] #1904870
09/02/15 01:32 PM
09/02/15 01:32 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
very nice and cooooll!
Re: Seats, Steering Wheel, and Seat Belt Options... [Re: MuuMuu101] #1905539
09/03/15 09:29 AM
09/03/15 09:29 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Great looking interior Bill.
I have the Corbeau seats in my GTX. One thing to consider , that I obviously did not, is if you are going to use retractable belts, the stock mounting point on the rocker panel side will need to be moved back because the lever to recline is right on top of the belt re-tractor. I had to swap the driver/passenger seats so that adjustment lever is now on the center console side. Somewhat inconvenient but I am not into and out of the back seat so much that it is a big hassle.
Driving modern convenience in classic beauty
Re: Seats, Steering Wheel, and Seat Belt Options... [Re: Darius] #1906475
09/04/15 07:13 PM
09/04/15 07:13 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
Hey, thanks!
Really, you had a problem with the retractors? That's interesting.
Do you have a pic of how yours was? I didn't run into a problem with the adjustment lever on mine.
Here's another shot of mine from a different angle. It's close, but once buckled there wasn't an issue.
Re: Seats, Steering Wheel, and Seat Belt Options... [Re: MuuMuu101] #1906766
09/05/15 09:57 AM
09/05/15 09:57 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I will take a pic. I think the difference appears to be I have the 3 point shoulder belt set up and the retractor spool mounts right along side of the adjustment lever on the seat. Just in front of the fire ext in your pic.
Those seats sure are comfortable though!
Page 4 of 4 1 2 3 4
