Page 11 of 26 1 2 9 10 11 12 13 25 26
Re: My 63 Dodge 330 Project: [Re: GY3] #428397
01/25/15 06:45 PM
01/25/15 06:45 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Thought this was a cool pic!
Re: My 63 Dodge 330 Project: [Re: GY3] #428398
02/07/15 08:27 PM
02/07/15 08:27 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Finally got the fuel lines,fittings and throttle lever for the Demon. Neighbor Dave fixed me up! Runs very nice with the new Double Pumper! Found a drop base for the aircleaner too as everything moved upwards into the hood. Pretty sure the extra stock flat hood that I have (with bracing removed like factory maxies) will clear now. Gonna take it and have it stripped in the next week or two so I can get rid of the silly looking scoop.
Re: My 63 Dodge 330 Project: [Re: GY3] #428399
02/14/15 10:38 PM
02/14/15 10:38 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My wife says: "You just got it together, why are you going to tear it apart again?!"
Women. They just don't unnastand!
Re: My 63 Dodge 330 Project: [Re: GY3] #428400
03/11/15 02:38 PM
03/11/15 02:38 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Pulled the top end off the motor and got the Stealth's painted. One bay in my garage looks like the parts box for a model car!
Re: My 63 Dodge 330 Project: [Re: GY3] #428401
03/11/15 02:47 PM
03/11/15 02:47 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Re: My 63 Dodge 330 Project: [Re: GY3] #428402
03/15/15 11:02 AM
03/15/15 11:02 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Motor going back together.
Re: My 63 Dodge 330 Project: [Re: GY3] #428403
03/15/15 10:01 PM
03/15/15 10:01 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Back together and running. Easiest swap ever! WHOOOO!
Re: My 63 Dodge 330 Project: [Re: Anonymous] #1802068
04/12/15 11:19 PM
04/12/15 11:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Got the car officially tagged, titled and insured this past week.
Drove it 150+ miles and had a ball.
It runs great, smooth as silk coming down from a few 1/4 mile blasts and never had a single issue!
Speedview app had me at 114 mph for my "high score" LOL! eek
Re: My 63 Dodge 330 Project: [Re: Anonymous] #1803803
04/14/15 11:59 PM
04/14/15 11:59 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It's the little things in life...
Thanks to Bill for getting me a pic of an original to show where they were when new.
Re: My 63 Dodge 330 Project: [Re: GY3] #1820484
05/06/15 07:48 PM
05/06/15 07:48 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
3,287lbs. with 1/2 tank of gas.
I was pretty happy with that number..
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #1835020
05/27/15 01:45 AM
05/27/15 01:45 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Well, crap!
Stock rod bolts suck. runaway
Fortunately I'd been gathering parts (block and rockers recently) to do a stroker shortblock. This just speeds up the process... wrench hammer
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #1843845
06/07/15 11:36 PM
06/07/15 11:36 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Pulling out the shortblock that went "KABOOM".
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #1843849
06/07/15 11:39 PM
06/07/15 11:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Trying to keep it organized.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #1854676
06/22/15 08:41 PM
06/22/15 08:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Had the heads pressure checked and the two valves replaced in the one head. Machinist said I was really lucky as the one bent valve had it's head come off in his hand as he was taking it out! runaway
He took a .010 cut off of both to get them flat again.
Top end is ready so I need to get the shortblock built..
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #1904869
09/02/15 01:28 PM
09/02/15 01:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I ordered a Molnar 4.25" stroke crank and 7.1" long rods along with Mahle pistons Friday. Flexplate, oil pan and balancer arrived today.
I'm anxious to get everything to my machinist!
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #1920534
09/27/15 12:30 PM
09/27/15 12:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I had some problems with getting an incorrect crank and they quickly remedied that but it slowed things down some.
The block has been cleaned, main studs installed, align honed and the decks evened up. He was putting it on the boring machine when I stopped by to swap cranks last week.
The heads went to Modern Cylinder Head for CNC porting on Friday.
Re: My 63 Dodge 330 Project: [Re: GY3] #1929460
10/10/15 07:56 AM
10/10/15 07:56 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
A little slow but making some progress. So far everything is fitting together nicely with no surprises. The combination balanced really nicely with minimal weight coming off the crank. The 4.25 stroke clears the oil pump pickup and bottoms of the bores with no block mods.
Re: My 63 Dodge 330 Project: [Re: GY3] #1939407
10/27/15 12:55 AM
10/27/15 12:55 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Making a little progress. Need to measure for pushrods and lash the valves and I'll button it up.
Re: My 63 Dodge 330 Project: [Re: GY3] #1949241
11/11/15 05:07 AM
11/11/15 05:07 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Dropped in the engine today.
Re: My 63 Dodge 330 Project: [Re: GY3] #1951273
11/14/15 10:50 PM
11/14/15 10:50 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wow! Fired for the first time today and it was definitely a different sounding motor! Looks exactly the same but the extra 3 points of compression, 65" and ported heads make a sound all their own!
