Caltrac questions
#190430
01/11/09 11:05 AM
01/11/09 11:05 AM
Posts: 326 Davenport, IA
70shaker
Davenport, IA
Can someone measure the distance from the bottom of the shock bracket to the cross hole for the rod? The article on the internet shows this about 2" but in the pictures I have seen this looks more like 4"-5".
Do you guys use rod ends or heim joints?
My Challenger springs have 6 leaves per side and I am debating whether to remove a few leaves.
Ex Hemi Racer 70 Challenger Hemi 4 speed clone
Re: Caltrac questions
[Re: 70shaker]
#190431
01/11/09 11:24 AM
01/11/09 11:24 AM
Posts: 411 Harleysville, PA USA
Tommy D
Hello. I am a B-Body guy, but one of my close friends has been running a '70 Challenger with SS leafs and the Cal Trac bars. His car is/was a 440-6, 4-speed, 4.56 Dana car. He ran a .557 solid cam with stock heads. With sticky tires, he launched and when the rear part of the springs separated, they pinched the rear valence. When the car settled down, it mangled the driver's side section of his, cherry valence. The car was running low 12's @ 116mph. Be careful with springs and Cal Tracs. I'll try to take some pictures of his set-up in the next couple of days. Unfortunately, my camera is set up to take pictures that are too big to post on this site. I need to figure how to take them with less resolution so I can post them. If you have an e-mal address, send me a PM. I'll forward what I have.
FYI, I spoke of the 44-6 in the past tense because he catastrophically destroyed the block when a rod let go. i have some pretty dramatic pictures of it. Good luck, and be careful. Tom
[Re: Tommy D]
#190432
01/11/09 11:36 AM
01/11/09 11:36 AM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
Edited out comment because I was mistaken in what I had been told.... My Bad....
70shaker, if I understand your question, mine measures 3" from the center of the rod to the actual mounting boss for the shock.
[Re: Tommy D]
#190434
01/11/09 12:03 PM
01/11/09 12:03 PM
Posts: 21,808 Kirkland, Washington
Pacnorthcuda
Many people run Caltracs with multiple-leaf springs. Caltracs does not state you can't (in fact they state you can). Its not as effective as their mono-leaf, and even less effective with SS springs but it can and is done.
A quick paste from their site:
Specializing in leafspring traction enhancement systems for over 15 years, the Calvert Racing Team knows what it takes to get your car hooking harder than ever! With unsurpassed quality and craftsmanship, all competition is eliminated. Why settle for anything less than the original system that set the standards?
Calvert Racing’s CalTracs are the most innovative traction bar units today, often imitated, but never duplicated.
If you have a leafspring car, we have a set of bars for you! From daily driven cars, to 8-second outlaw cars, this system is made to out perform!
Price: 339.00 Plus Shipping (California Add Sales Tax) Complete bolt-on, no cutting, welding, or modifications to OEM suspension.
Keeps axle from rotating, helping maintain pinion angle.
Improves 60ft times.
Full preload adjustability.
Eliminates spring wrap-up.
Powdercoated gloss black finish.
Full color Installation Guide.
PSCA, NMCA, NHRA approved.
[Re: Dart Racer]
#190435
01/11/09 12:29 PM
01/11/09 12:29 PM
70shaker
Davenport, IA
I need the measurement from the surface of the shock plate where it touches the spring to the cross hole for the bar. I need this dimension to make my brackets.
[Re: 70shaker]
#190436
01/11/09 12:48 PM
01/11/09 12:48 PM
Pacnorthcuda
OK, I just measured 3.5 inches from the center of the bar mounting hole to the bottom of the shock plate. The plate is .25" so 3.75 total
[Re: Pacnorthcuda]
#190437
01/11/09 01:43 PM
01/11/09 01:43 PM
70shaker
Davenport, IA
Thanks for the info guys.
Do these use heim joints or rod ends?
[Re: 70shaker]
#190438
01/11/09 01:55 PM
01/11/09 01:55 PM
Pacnorthcuda
I have always considered Heim joints and rod ends to be the same thing???
The caltracs DO have the captive sleave that pivots/swivels within the collar.
[Re: Pacnorthcuda]
#190439
01/11/09 02:32 PM
01/11/09 02:32 PM
Triple Threat
Renton Washington
The Heim Joint threads into the bars on caltracs. (male)
Rod ends thread over a length of rod. (female)
Thats the only real difference I have ever noted between the 2. One of those things where the names are interchangeable
[Re: Triple Threat]
#190440
01/11/09 02:43 PM
01/11/09 02:43 PM
Pacnorthcuda
Then by that definition (now I know!) yes, they are Heim joints.
[Re: 70blackfish]
#190442
01/11/09 05:33 PM
01/11/09 05:33 PM
70shaker
Davenport, IA
I have always known them with following terminology
Heim joint has the spherical rotating ball in the center and it can be male or female thread
Rod end does not have the spherical ball and it can be male or female thread
