70 Cuda Brake Caliper Brackets
#1903478
08/31/15 09:42 PM
08/31/15 09:42 PM
Posts: 567 Indianapolis, IN
B5Cuda440-6
Indianapolis, IN
Does anyone have a picture of correct 1970 disk brake caliper brackets? What numbers are cast into the (R) and (L) brackets?
Re: 70 Cuda Brake Caliper Brackets
[Re: B5Cuda440-6]
#1903485
08/31/15 09:50 PM
08/31/15 09:50 PM
Posts: 5,354 Rancho Cordova, California (Sa...
hemi71x
There is no left, or right, bracket. Both are the same. Numbers on them are just something from the foundry, that probably only meant something in the manufacturing process. Meangless to you and me, whatever they are.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: B5Cuda440-6]
#1903543
08/31/15 11:19 PM
08/31/15 11:19 PM
hemi71x
Do you know if there is a difference between 1970 and 1971 brackets?
Nope, none. Brackets never changed, in all the years that the pin type calipers were used on the cars, as far as i know, for the 10.8 inch rotors.
[Re: hemi71x]
#1903702
09/01/15 05:22 AM
09/01/15 05:22 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Nope, none. Brackets never changed, in all the years that the pin type calipers were used on the cars, as far as i know, for the 10.8 inch rotors. Yep
[Re: B5Cuda440-6]
#1903843
09/01/15 11:25 AM
09/01/15 11:25 AM
hemi71x
Thanks all for the great information and the help. If you have a picture of the 70 vs. 71 caliper, that would be great.
Is that what your after from the beginning? I have a pair of 70, early 71, single piston calipers, that i rebuilt, that i never put up for sale, so i have pictures in my computers files. I took pictures of the 70, early 71, with the "wide mouth" compared to what was used after that. You looking for a pair? e mail me. Won't be cheap though, i know what i have.
