Another 2dr conversion - 1962 Plymouth #1900759
08/27/15 11:52 PM
08/27/15 11:52 PM
Illinois
SGTFURY62 Offline OP
Illinois
Picked up this '62 Belvedere awhile back and decided to do another 2dr sedan conversion. I had access to a clapped out sedan for the quarter sections and traded for some rust free doors.
Today I removed the seats and trimmed down the donor sections. Tomorrow I'll remove the ds doors, bolt in the 2dr sedan door and test fit new quarter section. Will begin removing sheet metal in original rear door jam also to match what is supposed to be like for the 2dr sedan.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1900764
08/27/15 11:54 PM
08/27/15 11:54 PM
Illinois
Illinois
This was my first attempt. 63 Plymouth wagon. Wish I had kept.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1901103
08/28/15 02:13 PM
08/28/15 02:13 PM
Illinois
Illinois
A lot done this am.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1901903
08/29/15 04:26 PM
08/29/15 04:26 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
wow! great project. Is it really as easy as you're making it look? Not taking away from the work you're doing, just wondering how many nice solid four doors could have been saved over the years by doing this conversion. Love the look of the early B Bodies.
1981 Dodge D150 360 auto
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1902073
08/29/15 09:24 PM
08/29/15 09:24 PM
Illinois
Illinois
I think it's too easy. I've run across many of both and unfortunately years ago never thought about. Most of the sedans were soooo rusty and probably scrapped unfortunately and the 4drs gave up the parts. Hardest physical part of this conversion is the time consuming spot weld drilling and that's not even hard just time consuming.
I'm doing a 63 Plymouth after mine for a buddy. He couldn't find a true 2dr sedan he could afford that was solid.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1904216
09/01/15 04:53 PM
09/01/15 04:53 PM
Illinois
Illinois
Have done a little more trimming and fitting the last couple days. Have cut out where the rear door jam was. Did this to open up that area as it would be on the sedan. Spent extra time on getting drivers door aligned so could fit the donor quarter piece in and have it lined up so gaps are correct. Now that have everything fitted correctly I'll take it all apart again and sofa blast the donor quarter, door and drill the spot weld holes on the interior perimeter.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1904718
09/02/15 09:27 AM
09/02/15 09:27 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
lookin good!
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1906049
09/04/15 12:05 AM
09/04/15 12:05 AM
Illinois
Illinois
Coming along.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1906372
09/04/15 03:47 PM
09/04/15 03:47 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
fantastic work. your wagon looked killer up
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1906422
09/04/15 05:27 PM
09/04/15 05:27 PM
Illinois
Illinois
More work today.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1906432
09/04/15 05:50 PM
09/04/15 05:50 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Wow, look. A three door. whistling
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1906817
09/05/15 11:51 AM
09/05/15 11:51 AM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
Great work so far! I have a pair of 64 conversion panels I saved, I want to do this conversion.
HEMI,S ARE FOREVER!!!
Re: Another 2dr conversion - 1962 Plymouth [Re: 1969 HEMI R-T] #1907555
09/06/15 06:13 PM
09/06/15 06:13 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I like it!
Stan
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1916969
09/21/15 07:59 PM
09/21/15 07:59 PM
Illinois
Illinois
All welded in and body work roughed in. Looking pretty good. Need to fix a dent at door line still.
All welded and bodywork roughed in. Have to fix a dent near door line still.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1918193
09/23/15 05:15 PM
09/23/15 05:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Nicely done, what a great project!
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1918428
09/23/15 10:33 PM
09/23/15 10:33 PM
Illinois
Illinois
Was busy today. Took apart passenger side, bolted in door and aligned donor section
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1924103
10/02/15 01:26 PM
10/02/15 01:26 PM
Illinois
Illinois
All welded up.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1925024
10/03/15 05:25 PM
10/03/15 05:25 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
thumbs
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1928068
10/07/15 11:40 PM
10/07/15 11:40 PM
Illinois
Illinois
All done with the conversion. Now time to strip trim and massage rest of car in prep for paint.
Re: Another 2dr conversion - 1962 Plymouth [Re: SGTFURY62] #1928244
10/08/15 10:39 AM
10/08/15 10:39 AM
Minnesota
peabodyracing Offline
Minnesota
Great job! You're a talented guy as you make it look easy.
Darn it you've now got me out looking at my 4 dr 62 (the one you sold me the door panels for) wondering if I should do the same thing.
Keep up the good work. Anxious to see it finished.
Lead, follow or get the hell out of the way
