sb heads lift? #189934
01/10/09 09:21 PM
01/10/09 09:21 PM
bc canada
67valiant Offline OP
bc canada
what is the max lift you can get away with on a set of j heads with out doing any mods do them
Re: sb heads lift? [Re: 67valiant] #189935
01/10/09 09:23 PM
01/10/09 09:23 PM
Renton Washington
Triple Threat Offline
Renton Washington
I'm assuming you would at least put valve springs in them.
Keep the lift under .500 and you should be ok.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: sb heads lift? [Re: 67valiant] #189936
01/10/09 09:26 PM
01/10/09 09:26 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my first experiance with a cam change on a small block saw a failure at the valve lock area. the grooves were hammered out. turns out the bottom of the locks were touching the top of the guide. this cam was 520 lift.
Re: sb heads lift? [Re: rebel] #189937
01/10/09 09:32 PM
01/10/09 09:32 PM
bc canada
bc canada
ya that what i thinking will happen im running a 509 with no problems so far but was thinking on bigger
Re: sb heads lift? [Re: 67valiant] #189938
01/10/09 09:57 PM
01/10/09 09:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just machine the guides down and go to the Viton
seals at that time..... very easy to do
Re: sb heads lift? [Re: MR_P_BODY] #189939
01/10/09 10:07 PM
01/10/09 10:07 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you use the OEM type umbrella seal all you need to do is trim the tops of the guides some with a cut off. It is not a critical area and don't take a precision cut unless you use teh Perfect ccircle type of seal. Just don't leave any burrs on the inner guide area. There is plenty of guide there that you won't hurt anything.
Re: sb heads lift? [Re: MoparforLife] #189940
01/10/09 10:36 PM
01/10/09 10:36 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Using retainers/locks with a higher install height like they do in this article would help"
http://www.compcams.com/Community/Articles/Details.asp?ID=-738676943
Re: sb heads lift? [Re: 69Cuda340S] #189941
01/10/09 11:10 PM
01/10/09 11:10 PM
bc canada
bc canada
i was thinking that also as to cutting them but if i gotta take the heads off to do that im gonna go all the way and do it right that guys
