KB maincap tool pics? #189472
01/10/09 03:20 PM
01/10/09 03:20 PM
communist bloc of new jersey
jamesc Offline OP
jamesc  Offline OP
looking for ideas on a tool for the KB maincaps. i know some here have made them, got some pics?
Re: KB maincap tool pics? [Re: jamesc] #189473
01/10/09 03:21 PM
01/10/09 03:21 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
You mean a cap removal slide hammer?
Re: KB maincap tool pics? [Re: jamesc] #189474
01/10/09 03:48 PM
01/10/09 03:48 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i just got a digital camera but havent even used it yet. Mine looks like a bridge. bolts to the pan rail holes. I bolt a harmonic bal puller to it and use that to push the caps down, To pull them out, i just use a threaded rod with a nut and washer, it works VERY well...sorry that i can put a pic up
It basically a pice of angle iron that spans the cap with a leg on each side that bolts to the pan rail. there is a hole drilled in the middle, When you thread a threaded rod into the cap, all you need is a washer and a nut on the rod , as you tighten it the cap just somes out so nice and easy. Like i say, i also bolt on my puller with two bolts, now to install a cap i put a small square of 1/4 alum to keep from galling the cap, then u just use the pullers shaft to push the cap down, again nice and easy. Just make sure to use a little oil so the cap doesnt gall on the sides going in and or out
....BAD A$$ STREET CAR.....
Re: KB maincap tool pics? [Re: n20mstr] #189475
01/10/09 04:01 PM
01/10/09 04:01 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Here's what I use for both KB and normal blocks.
I bought the slide hammer at a Lowes.
The tongs are great for a Mopar block that doesn't have a threaded pull hole.
Then the tongs unscrew so I just us the threaded portion for the KB caps.
"Great tool" that makes your life easy.
