Drag Radials on oem steel wheels? #1885030
08/04/15 04:16 PM
08/04/15 04:16 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Me again,
Im trying to build my bracket/street car with a day two/stealth look to it and Ive even got the race block looking oem and ground a few thing off so the unsuspecting ford of chevy guy wont think any different.
So I mounted the DR-s on the rims and since ive got the long studs ive got room for as much as a 1/8 or so plate on each side of the rim but im not fully sure how to make this "sandwich" work.
Id almost think if I welded them it might make it easy for them to crack? Or I could in a triangle pattend drill and use some pressed in hardened pins. My wheel centers would cover it all, but I know when its time to get real busy and hook, the oem rims and acorns wont last or be safe.
Thanks!
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885128
08/04/15 07:16 PM
08/04/15 07:16 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I wouldn't use any type of spacer. I just have Nitto DR on ralley rims and short hi strength studs.
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885161
08/04/15 08:21 PM
08/04/15 08:21 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
My old dog dish's cleared long studs.
Mopar to the bone!!!
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885169
08/04/15 08:32 PM
08/04/15 08:32 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Not really clear what you are trying to accomplish.
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885186
08/04/15 09:13 PM
08/04/15 09:13 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
I wasnt going to use them for actual spacing but to try to add strength to the center and lesson the chance of egg shaping the lug holes.
Ive a 73 SD455 pontiac with drag radials and it ate up a set of nos rims last summer so I replaced the rims and studs this spring and that was with a mild vert and 3:42 gears. This setup will launch about 5200 off the brake with a 4:56 gear.
Its been hard to determine a actual tq number on the acorns as to whats too loose and whats going to dig into the rims so I so ive just been getting them pretty tight.
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885221
08/04/15 10:05 PM
08/04/15 10:05 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
This is with 3" studs
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885399
08/05/15 02:44 AM
08/05/15 02:44 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Still not exactly sure what I'm trying to understand here. You're saying you ruined a set of rims?? OEM rims that are steel.... and you ruined them by the studs egg-shaping the lug-holes Are you sure about this? That must be some serious torque and hook!!!
I run 15x7 Steelies with 255/60-15 ET Street Radials. Dr. Diff axles with short hardened studs & conical style lugs... Never had an issue. But admittedly, my car is not a beast.
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885445
08/05/15 08:40 AM
08/05/15 08:40 AM
P
Porter67 Offline OP
Porter67  Offline OP
P
Im probably worried over something that wont happen again, but yea my pontiac runs pretty hard, a 73 SD455 T/A.
I also destroyed two turbo 400s and one carrier unit last summer. Its as strong as any mopar ive ever had and the only gm ive ever owned.
But it looks like im worried for not, just dont want to kill a set of new, old rims.
Re: Drag Radials on oem steel wheels? [Re: RV2] #1885446
08/05/15 08:42 AM
08/05/15 08:42 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
that is way cool!
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885448
08/05/15 08:43 AM
08/05/15 08:43 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If you screwed up rims, it was because something else was wrong.
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885478
08/05/15 10:11 AM
08/05/15 10:11 AM
P
Porter67 Offline OP
Porter67  Offline OP
P
Maybe the quality of the material used or the thickness, which I think possibly might of been the problem.
So it looks like I will just run these and hope for the best.
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1885506
08/05/15 11:30 AM
08/05/15 11:30 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
GM cars use 7/16" studs. Mopars use 1/2".
Re: Drag Radials on oem steel wheels? [Re: BSB67] #1885810
08/05/15 07:22 PM
08/05/15 07:22 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
that is way cool!
Re: Drag Radials on oem steel wheels? [Re: DoctorDiff] #1885966
08/05/15 11:13 PM
08/05/15 11:13 PM
moparx Offline
moparx  Offline
and i have seen lug nuts for steel wheels that were 1" hex size instead of the mopar standard 3/4" hex. that should add more clamping force i would think, because of a greater contact area of the conical seat ?
beer
Re: Drag Radials on oem steel wheels? [Re: Porter67] #1886028
08/06/15 12:27 AM
08/06/15 12:27 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Because of the 1/2" studs, I have always torqued to 100 ft/lbs.
