TKO - 500 Shifting Problems
#1884687
08/03/15 11:18 PM
08/03/15 11:18 PM
Posts: 450 OHIO
faud88
OHIO
I have TKO-500 that has been in my car for the last couple of years. On Saturday out of the blue I started having problems shifting into 1st gear. All of the other gears perform as needed but it will not shift into 1st. I am running the hydraulic clutch setup as well. Any help or thoughts would be appreciated.
[image]https://board.moparts.org/ubbthreads/upload2/5353101-YoungGunChallengerNats.jpg[image]
My 70 Dodge Challenger R/T SE 383 Magnum, 727, A/C, Cruise, Six-way seat.
Re: TKO - 500 Shifting Problems
[Re: faud88]
#1884932
08/04/15 01:26 PM
08/04/15 01:26 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Try to bleed the clutch to ensure you didn't pull in air from anywhere. The other gears aren't a problem when shifting, since you don't need a clutch to shift once the RPMs drop and engine speed matches the next hear--it'll fall into gear without using a clutch
**Photobucket sucks**
[Re: faud88]
#1886155
08/06/15 10:11 AM
08/06/15 10:11 AM
70Cuda383
Marysville, O-H-I-O
I will try bleeding the clutch again. It shifts into reverse flawlessly.
Hmm...that is a strike against it being the hydraulics of the clutch, if it wasn't fully disengaging because of air in the system, it would also be hard to shift into reverse I would think.
