Re: I'm A Happy Camper Again
[Re: sunroofgtx]
#188469
01/10/09 10:05 AM
01/10/09 10:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have to go in for some testing on Monday and Tuesday due to things just arent quite right yet
And you are still thinking thats different than before ??? Nice to hear you are back, Mike.. Really. Your wife is too good to leave her in the hands of another CC @ Norwalk by herself !! LOL.. Glad to hear the team is still together..
She's in good hands ........ mine Feels so good to have my mill back up and running
#188471
01/10/09 11:49 AM
01/10/09 11:49 AM
MR_P_BODY
with Bubba! Rick's a great guy,with an awesome car! Raff,will you be home this afternoon? If so,I plan on stopping by for a chat,and return the Holley,for which I'm VERY thankful for your generosity! Glad to hear your feeling better! RandyB
Randy, I'll be here all day.... give me a call when you come... also if your rockers are off.... bring a couple(mostly the intake one)
[Re: Moore & Moore]
#188473
01/10/09 12:01 PM
01/10/09 12:01 PM
MR_P_BODY
Mr P glad you are doing better. What type of mill do you have? Jack
Just a power feed table Allied(same as a Bridgeport) none of the fancy CNC stuff
[Re: RickRoss]
#188474
01/10/09 12:10 PM
01/10/09 12:10 PM
Posts: 2,475 SW Ohio
cgall
SW Ohio
This is actually a very good suggestion. As a former shop supervisor, I would always tell the guys to make sure that someone else knew if they were going to be in the shop alone. That way someone could check up on them after a while.
Some crazy things happened in the 5 years I was there, once a guy was turning a steel shaft and left too much hanging out the back unsupported, it started to wobble and then broke off and went straight up into the roof and stuck there! Had to get a roofer to fix the hole.
Another time a guy put a 2000 rpm max grinding wheel on a 10,000 rpm die grinder, again, it whizzed along for awhile, then flew off and broke the window on our vertical cnc machine.
There were no injuries I can remember in my time there, just close calls. If someone were hurt, though, I wanted someone else to be around to call an ambulance.
[Re: markz528]
#188477
01/10/09 04:30 PM
01/10/09 04:30 PM
MR_P_BODY
What kind of converter are you using? Many people don't realize that converters don't make sense any more in today's day and age. You should be using VFDs (variable speed drive). The benefit is single phase in, 3 phase out, variable speed and if you get the right one dynamic braking - - sure is nice to have the mill stop spinning in 1 revolution without mechanical assistance. They can be had cheap on ebay. I have 4 vfds in my new shop.
I'm using the electronic type.... I couldnt see running a big motor to run my small motor. My old electronic one was too small to handle the HP but this one will handle a motor twice the size of mine... this one also starts much faster than the old converter
[Re: Mrs_P_BODY]
#188479
01/10/09 06:48 PM
01/10/09 06:48 PM
Posts: 482 Michigan
BigFish69
Hey Mike If you want your wife to keep a better eye on you just up the life insurance policy. Oh wait that may not be a good idea. Glade your feeling better and that small block thing you and Rick will see the light one day
[Re: BigFish69]
#188480
01/10/09 06:52 PM
01/10/09 06:52 PM
MR_P_BODY
I'm worth ALOT more dead than I am alive.... and she knows it
