Possible ET loss from gear ratio change
#188399
01/09/09 11:09 AM
01/09/09 11:09 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Starting the fabbing process of putting a Dana under my junk. My question is how much et would I lose dropping from 4.30s to 4.10s? My combo is a 10.6 to 1 440, in a 3800 lb car, 28 inch tall ET street radials, 8 inch TA converter that flashes 4900ish. Best ET is 11.33@ 117.72, turns 6500 out the back. Best ets are shifting at 6200.
Ive got 4.30s in the 8 3/4 in it now and Ive got a 4.10 R&P for the 60 already, Id like to not have to buy 4.30s unless there is gonna be a big difference.
What ya think?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Possible ET loss from gear ratio change
[Re: Von]
#188400
01/09/09 11:38 AM
01/09/09 11:38 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
You may not see much difference. While I did make some other slight changes to mine I went from a 4:88 to a 4:56 and so far it has stayed pretty close ET wise. I did have to play around with the shift point a bit to find the new sweet spot but I'm not sure if that was due to the new gear or the slightly bigger cam. (I went from a 525 hyd to a 555 sld with roughly the same dur.)
My is if you already have them, use them and if you find it doesn't like it it's not that tough to swap them out later.
[Re: Von]
#188401
01/09/09 11:42 AM
01/09/09 11:42 AM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
went from 8 3/4 with 4.30 gear to dane 60 with 4.10 gear and picked up a tenth
WAXER
[Re: WILD BILL]
#188404
01/09/09 02:08 PM
01/09/09 02:08 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I tried going to a 4.10 from a 4.30 and ran the same ET but was more consistent with the 4.30's.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#188405
01/09/09 03:06 PM
01/09/09 03:06 PM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
Im thinking you will not gain any ET but loose it, What are your plans for the car, is it street strip or just all out race car? I myself would run a higher gear, 3.91 or 3.73 gear with a 28" tire but thats just me, you have a BB with gobs of low end. Should pull like crazy out of the hole with little RPM....My Phill
