know these tubular upper control arms??? #1883645
08/02/15 05:33 PM
08/02/15 05:33 PM
central texas
K
krautrock Offline OP
K
central texas
just bought a 67 coronet and trying to figure out who made these upper control arms, anyone recognize them?
notice the gusset...
Untitled by misomad, on Flickr
Re: know these tubular upper control arms??? [Re: krautrock] #1883646
08/02/15 05:39 PM
08/02/15 05:39 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
They look like FirmFeels... They even have the support at the balljoint. Maybe it's an older model?
http://firmfeel.com/b_body_mopar_upper_control_arms.html
Re: know these tubular upper control arms??? [Re: krautrock] #1883749
08/02/15 08:13 PM
08/02/15 08:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
RMS. the firm feel ones are similar but I have the same ones and I want firm feel ones. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: know these tubular upper control arms??? [Re: krautrock] #1883750
08/02/15 08:14 PM
08/02/15 08:14 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: know these tubular upper control arms??? [Re: krautrock] #1883779
08/02/15 08:58 PM
08/02/15 08:58 PM
central texas
K
K
central texas
oh alright, so rms are different than the PAC arms that i saw had a few failures?
anyone know if there should be part numbers on the spindle (where?), i'm guessing it probably has the 73-74 a-body spindles but the seller wasn't sure.
gonna check the lower ball joints, one looks pretty old, car drives like it needs an alignment so i figure lower ball joints and maybe some bigger front torsion bars would be good...and new shocks...
Re: know these tubular upper control arms??? [Re: krautrock] #1883985
08/03/15 12:26 AM
08/03/15 12:26 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I don't think they are rms. Im pretty sure he doesn't use the gusset. they also look like they are mig welded, cold. rms arms are tig welded. those are look like CAP to me.
Re: know these tubular upper control arms??? [Re: krautrock] #1884128
08/03/15 09:59 AM
08/03/15 09:59 AM
central texas
K
K
central texas
did the PAC arms have the gusset? the pics of the broken ones i've seen don't seem to...
seems these might be some older arms that might now be redesigned.
Re: know these tubular upper control arms??? [Re: krautrock] #1884429
08/03/15 04:47 PM
08/03/15 04:47 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The pics are NOT of the FF uca.... because FF doesn't have the adjustments at the ends (all of their pos/caster and neg/camber is pre-built into the design of their uca... and you do the final alignment with the factory cam bolts. I believe the pictured uca are CAP or QA1 (QA1 bought out CAP)... looks like they are heim-joint adjustable ends... that is what the CAP/QA1 uca are.
Re: know these tubular upper control arms??? [Re: krautrock] #1885510
08/05/15 11:45 AM
08/05/15 11:45 AM
central texas
K
K
central texas
oh, heard from the previous owner, he said they are QA1 and he didn't like them. said he never thought he got them adjusted right though he followed the directions.
so that said, i'm going to have this thing aligned soon.
what is a good baseline on the upper arms adjustment so the alignment guy can get around 5* caster and maybe negative camber around .5* to 1*
could that be done with all the adjusters all the way in?
or should i go all the way in on the rear and a few threads out on the front bushings?
it's not driving terrible, goes straight but tries to pull a little to the left on the hwy if i tip in the throttle. also kinda darty like it might be toed out just a tad...
