1984 Dodge D100/D150 gas tank strap #1883682
08/02/15 06:34 PM
08/02/15 06:34 PM
USA
360D100 Offline OP
360D100  Offline OP
USA
Does anyone know where you can get a rear gas tank strap for a 1984 Dodge D100? I have been looking but have not been able to find one yet. Would it be possible to make one? Thanks
Re: 1984 Dodge D100/D150 gas tank strap [Re: 360D100] #1883782
08/02/15 09:01 PM
08/02/15 09:01 PM
scratchnfotraction Offline
yes, weld a bolt to a 2" wide strip of sheet metal and a piece of 2" angle.
drill 2 holes in the angle piece to bot to frame. bolt goes thru upper cross member.
I had the local metal shop cut the strip. 5$ and 3$ for bolt/angle.
Re: 1984 Dodge D100/D150 gas tank strap [Re: 360D100] #1883791
08/02/15 09:06 PM
08/02/15 09:06 PM
USA
360D100 Offline OP
360D100  Offline OP
USA
Thanks. Are there no new straps available for the older trucks? I cant find any anywhere.
Re: 1984 Dodge D100/D150 gas tank strap [Re: 360D100] #1883798
08/02/15 09:18 PM
08/02/15 09:18 PM
places
79powerwagon Offline
places
Nope. I couldn't even find them back in teh 90's! Fab your own.
Re: 1984 Dodge D100/D150 gas tank strap [Re: 360D100] #1884110
08/03/15 08:39 AM
08/03/15 08:39 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Doran or. Spectra make straps door them.
Angry white pureblood male
Re: 1984 Dodge D100/D150 gas tank strap [Re: ruderunner] #1884112
08/03/15 09:08 AM
08/03/15 09:08 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
The ones I have seen are for 88-93. Have not found any for anything older. Do u know where u saw those at? Thanks
Re: 1984 Dodge D100/D150 gas tank strap [Re: 360D100] #1884140
08/03/15 10:30 AM
08/03/15 10:30 AM
FYI, I just looked them up on ebay
new fuel gas tank strap 6" frame rail
Dorman 578-215 = 88 d100 = 52.90 free ship
also seen other in the 42$ range but a dozen or more listings.
Re: 1984 Dodge D100/D150 gas tank strap [Re: scratchnfotraction] #1884142
08/03/15 10:33 AM
08/03/15 10:33 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
Will those ones for a 88 work on a 84? Those ones I have found are listed for 88-93. I did see a different part number for the earlier trucks but it wasn't available.
Re: 1984 Dodge D100/D150 gas tank strap [Re: 360D100] #1884148
08/03/15 10:44 AM
08/03/15 10:44 AM
IIRC they should be the same. I have sold a few off junk trucks for members that had mid 80s trucks in general.
I think the straps are about the same and the tanks are different size/gallon.
my 35 gallon tank in the 85 stepside went from axle to up under the seat area.
stuck a 18 gallon tank right in there with those same straps. went from axle to front of bed area and not under the cab.
I had a hole drilled in the bed on one of those trucks to get the nut on the stud end of the strap.
I have made a couple easy enough. but now the 440 truck has a fuel cell and I used a 70 mustang tank behind the axle (like a RC/TD) in the 85 stepside.
I would have 2 set but just junked both trucks last month. sorry.
Re: 1984 Dodge D100/D150 gas tank strap [Re: 360D100] #1884241
08/03/15 01:04 PM
08/03/15 01:04 PM
USA
360D100 Offline OP
360D100  Offline OP
USA
Thanks. I ordered them for a 88. Will have them tonight. Hopefully they will work!!
