Re: cooling system advice needed
[Re: RapidRobert]
#1881084
07/29/15 09:36 PM
07/29/15 09:36 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
but during the summer months here in TN. it wants to run 210-220 degrees. Im not sure what to do with it.. this is stop & go I am assuming? I'd try a rigid fan blade properly spaced into the schroud if you have one laying around & other than that as said you might just need more radiator. I got a 2 core Champion off of evilbay for $189 to my door which ain't bad & I only had to redrill one hole in the dr side flat flange & it cooled OK but a DD 318 sure ain't gonna test its cooling capabilities No, it gets warmer if sitting still for a long period..
[Re: mopower440]
#1881112
07/29/15 09:53 PM
07/29/15 09:53 PM
RapidRobert
No, it gets warmer if sitting still for a long period.. & that is even worse than stop and go cuz the pump (water flow) and fan (air flow) speeds are the slowest they can possibly be plus not even a hint of air being forced in cuz of no forward vehicle movement
[Re: lewtot184]
#1881291
07/30/15 01:31 AM
07/30/15 01:31 AM
Posts: 954 garnett kansas
rhad
garnett kansas
a problem you may run across on a recore is the bottom tank. a 4 row will need a 2 5/8" wide bottom tank and 2" wide bottom tank won't take more than 3 rows. also, keep track of tube spacing; stay somewhere around 3/8"-7/16". being in the radiator business for 35 yrs i can tell you that its possible to expand a bottom tank from 2inch to 2 3/4 inch,any good rad shop should know how to do it
my ladder of success is missing some rungs
[Re: RapidRobert]
#1881352
07/30/15 07:49 AM
07/30/15 07:49 AM
Posts: 1,805 ky hills
thehemikid
ky hills
No, it gets warmer if sitting still for a long period.. & that is even worse than stop and go cuz the pump (water flow) and fan (air flow) speeds are the slowest they can possibly be plus not even a hint of air being forced in cuz of no forward vehicle movement That's one of the main reasons I went with the Monster fan. Controller picks up the fan speed as needed without adding more fuel to the fire.
