ladder bars? up or down #188089
01/08/09 07:52 PM
01/08/09 07:52 PM
tampa, fl
MaxAxe3 Offline OP
MaxAxe3  Offline OP
tampa, fl
got an old baracuda that was an ex gasser back in the day..it has ladder bars AND a single leaf spring..old style suspension again from back in the day.. how does he adjustment set?? it is all the way down..car seems to hook pretty good ( has 14x32's)but seems to be kinda soft..took out last night and was not pleased with performance over what we had before, but we got some bugs and tuning to work out. it sets really high in the rear and does not seem to transfer good.would moving the adjustment up toward the floor pan help or hinder?? never ran anything that didn't have basically stock suspension, so i'm learning!! thanks to all!!
4933580-HEADSUP.eml (103 downloads)
Re: ladder bars? up or down [Re: MaxAxe3] #188090
01/08/09 08:19 PM
01/08/09 08:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the higher the front is set the harder
it hits the tire. The more power you apply the
lower you can go with the front heim. Also the
higher it is the shorter the hit is on the tire,
in other words if it hits the tire then spins,
lower it some, the lower the bar the longer the hit is
Re: ladder bars? up or down [Re: MaxAxe3] #188091
01/09/09 09:56 PM
01/09/09 09:56 PM
Tampa, Fl
valiantboy Offline
super gas
valiantboy  Offline
super gas
Tampa, Fl
how much do the rear shocks have to do with the setup? the shocks on it now are just normal old gas shocks. will a softer shock help things? thinking of adj shocks?
I'm WAY too baked to drive to the devil's house.
Re: ladder bars? up or down [Re: valiantboy] #188092
01/10/09 12:20 AM
01/10/09 12:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A ladder bar car needs GOOD adjustable shocks, the
bars are going to give you alot of body seperation
and you have to control that and thats done with
good adjustable shocks. You might find that you will
be at or near the max setting on extension, depending
on what shock you use
