Re: Best Compression Ratio for Best MPG - 440 Question
[Re: WyleECoyote]
#1877247
07/24/15 02:03 PM
07/24/15 02:03 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
From a financial and practical point of view I would get the overdrive and a set of 3.08's or 3.54's first. Used transmissions can be had for $500 and up, and those diffs are everywhere, probably $250 to $500.
For a thousand bucks you will pick up at least 5mpg, and maybe up to 7mpg more.
FWIW, a 488 V10's have been known to get 15, 16mpg so there is no reason a 440 can't do it as well.
All highway mpg I'm quoting, if this is in town use then everything goes out the window.
Mo' Farts
Moderated by "tbagger".
[Re: HotRodDave]
#1879008
07/27/15 11:43 AM
07/27/15 11:43 AM
DaytonaTurbo
Manitoba, Canada
I ran 10-1 with an iron head 318 in an extended cab long bed 98 ram with a stock cam and very tight quench, even pulling a 65 dart on an open trailer and a bed full of parts out of LA on the big pass it never pinged on 87 octane california crap gas. I would expect the smaller displacement is coming into play there as well.
[Re: WO23Coronet]
#1879224
07/27/15 03:57 PM
07/27/15 03:57 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
I really wish I could find Dunnuk's article, he got ridiculous mileage with his 440, I'm sure it was 20 when empty I read same art. He used a comp cam hdy. roller kinda big but was in mid 20s on fuel mileage in a car. I kept article but cant find it either, maybe he will we this and help Might add the cam had some weird numbers for duration.
