Re: HP limit for 440 Block, filled & alum caps
[Re: Efidart]
#186633
01/07/09 09:55 PM
01/07/09 09:55 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Did 985RWHP on a short filled, aluminum capped and girdled destroked 440 turbo'd 388 cube. Mains looked like new after a year of beating on it.
Then I wised up bought a KB block and made more power on less boost with some more cubes.
Thanks for the info
[Re: sickhemi]
#186637
01/08/09 03:13 AM
01/08/09 03:13 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
didn't all the cylinder splitting happen recently with the long stroke cranks and short skirt pistons loading the cylinder walls or do they also split with stock stroke cranks?
I have seen several 400 blocks with 3.75 strokers split the cylinders with 6.76 long rods. My 1976 400 block with 6.8 long rods and a 4.300 stroker hasn't split one yet, thinness spot sonic testing in any of the cylinders was .163, thickess was .230 after boring I have seen thinner and thicker stock blocks As already said you have to test a bunch of them to find a really good one, that is the reason I bought one of the new World wedge blocks at 4.500 bore I have sonic tested it on the thrust sides,it is siamese bore, and the thinness I found was .300 That rascal is heavy though
[Re: moparmanjames]
#186638
01/08/09 07:24 AM
01/08/09 07:24 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
My block supposedly has been sonic checked and was in a naturally aspirated 505 alky digger. It's .030 over so I was going to take it .060 and hope for the best, but I'd really like to come across a deal on an aftermarket block. Thanks for the info.
do you have to take it to .060 or will it cleanup at .040?[keeping cylinder wall as thick as can be.]as $$ permits i would like to find a better block also a KP440 or KB aluminum.
