Re: Mopar powered Volksrod
[Re: 426W8bbl]
#1860601
06/30/15 04:25 PM
06/30/15 04:25 PM
Posts: 17 WA
426W8bbl
WA
Here are the specs of the 426 Wedge that will power my Volksrod.
426 Wedge (Built to Street Hemi specs)
Block- '59 413 (from Chrysler 300E, 1 of 690) bored to 426 stock- 4.25" (.062 over) Casting # 1851629-5 ID pad- MR413 9707
Heads- '68 440 #2951250- 2.08 intake, 1.74 exhaust valves P3690933 Street Hemi valve springs, steel spring retainers, umbrella valve seals
Valve Gear- Isky adjustable rocker arms on TRW hardened rocker shafts, Isky HD pushrods
Camshaft- Direct Connection "Hemi Grind" P4120235- 284* duration, .484" lift, 68* overlap, 108* centerline TRW double roller timing chain set
Pistons- TRW forged 11.0:1- .085" of dome shaved to drop ratio to 10.25:1- compression rings are moly-coated
Connecting Rods- stock forged steel, pressed wrist pin, Clevite tri-metal bearings, P4120068 rod bolt & nut kit
Crankshaft- Stock forged steel, chamfered & polished, P2836118 main bearings, stock dampener, stock steel 10.5" flywheel *entire rotating assembly has been balanced*
Oiling system- stock oil pump, Hemi relief spring, P3571071 intermediate shaft (hardened pump drive tip)
Distributor- #3690432 electronic, fast advance springs
Carbs & manifold- 2 Pontiac '64 389 AFB (525 cfm each) '59 Chrysler 300E inline dual 4 barrel manifold casting #1854817-1 prod. date H 17 8 one-to-one throttle linkage
chrome accessories- P4120224 timing chain cover P4120609 valve covers P4120446 valve cover breathr
*P-part# are from Direct Connection/Mopar Performance*
[Re: 426W8bbl]
#1861739
07/02/15 01:00 AM
07/02/15 01:00 AM
Posts: 2,340 west palm beach, florida
modelmakerinc
Well, you are not alone brother. I built my volksrod much less radical than you are planning.
But I think it should be really cool, what are you planning for front suspension, and im guessing you are familiar with volksrods.com
[Re: 426W8bbl]
#1861824
07/02/15 05:09 AM
07/02/15 05:09 AM
Posts: 17 WA
426W8bbl
WA
Im going to use a '40 Ford front axle with split wisbones, quarter elliptic springs and a disc brake conversion on the Ford spindles. Yes, I have gotten alot of ideas from cars on volksrod.com
[Re: 426W8bbl]
#1862100
07/02/15 03:52 PM
07/02/15 03:52 PM
Posts: 17 WA
426W8bbl
WA
Modelmakerinc, Very Nice V-rod!!
[Re: 426W8bbl]
#1862647
07/03/15 05:03 AM
07/03/15 05:03 AM
Posts: 17 WA
426W8bbl
WA
Thanks for the pics. It gives me another magazine to search for. My back fenders will be radiused big enough to fit a 30"-31" tire. I wont have front fenders. I will post some construction pics in the next couple days. Too bad they didnt use a Hemi in the Durachrome bug.
[Re: 426W8bbl]
#1881326
07/30/15 03:54 AM
07/30/15 03:54 AM
Posts: 1 CO
79MagnumGTE58
CO
That looks wicked 426W... Keep the pics comin'!
2006 Hemi 1500 MegaCab 2002 Jeep Grand Cherokee
