2008 Ram: A./C clutch coil and blend door questions?
#1865521
07/06/15 11:28 PM
07/06/15 11:28 PM
Posts: 364 Houston, Texas
Slant6pak
Houston, Texas
Hey guys,
Got a question about my 2008 Ram. The A/C has been out for the last two years (in Texas) and I've been to lazy to do anything about because I work 5 minutes from home.
Well that is about to change and I'm working on repairing it.
I'm traced my lack of A/C to the A/C clutch coil, its toast and I've found info on the web that this is a common problem and that is easy to repair ($40 and a hour so they say), but I can't find a part number or source for the part or instructions on how to change it. Can somebody point me in the right direction?
Also, I have infamous broken blend door in my A/C box, I found a website (HeaterTreater) that sells a repair kit. Has anybody used it?
2016 Challenger Scat Pack Shaker 1000 ci Brass Era Speedster project
Re: 2008 Ram: A./C clutch coil and blend door questions?
[Re: Slant6pak]
#1865773
07/07/15 11:34 AM
07/07/15 11:34 AM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
I replaced the recirc. door and a/c clutch on my '06 earlier this year. Check youtube for info on the clutch (I'm sure there is plenty there)- I'm a retired mechanic so I knew how to do it already. As for the recirc. door, I ordered one from RockAuto. It's so easy to replace I didn't see the need to pay HeaterTreaters price. Edit: Missed where you said blend door. Sorry. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Slant6pak]
#1866330
07/08/15 01:54 AM
07/08/15 01:54 AM
Slant6pak
Houston, Texas
Any other source for the coil besides the dealer?
Some of the info I read mentioned ebay... but they don't cross reference part numbers so well.
How the heck do you change it? I imagine the clutch has to come off...
As far as the broken door in the dash goes, I'm not sure which one is broken, maybe all this point.
When the A/C was still working, it blew fire out of the driver's side vents and ice cubes out the passenger side. I was thinking going with the Heater Treater kit because it replaces the flimsy plastic doors and you don't have to tear the whole dash apart.
[Re: stumpy]
#1867162
07/09/15 12:54 PM
07/09/15 12:54 PM
Posts: 856 Southeast Pa.
SALEM1912
Southeast Pa.
BTW you have tried to rotate the compressor to make sure it hasn't seized? The inter part or maybe just put a 13mm(maybe 10mm) socket on the center nut and rotate it. You should spin with a little drag.
[Re: Slant6pak]
#1868160
07/11/15 11:09 AM
07/11/15 11:09 AM
Posts: 13,572 md
mopars4ever
md
[Re: Slant6pak]
#1868297
07/11/15 04:54 PM
07/11/15 04:54 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
I'm doing this exact thing now. I have voltage going to the compressor. I can not spin the compressor at all. My blend door will be next. I wish those pics worked on the above link for plugs.
BTW, it is an 8mm center nut. Mine will loosen, but will not spin the compressor in the tightening direction.
I think a whole compressor is in my unfortunate future.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
