Re: Viper 6 speed in 1970 Challenger?
[Re: Spartan040]
#1863304
07/04/15 04:33 AM
07/04/15 04:33 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I have a 6 speed T56 in my 2005 GTO. Love it but never use 5th gear. I shift from 4th to 6th on the highway, because I'm already at cruising speed when I'm finished with 4th gear.
The only use for 5th is when cruising at 40-50 mph, and 4th seems just as good or better for that.
My 5th gear is 0.74:1 and 6th is 0.5:1 with a 3.73 rear end. In 6th gear at 65-70 mph, the engine is doing 1,800 rpm. I think the 0.5:1 is just right for highway, considering my rear end ratio. I'm not sure, but I don't think a 5-speed will deliver 0.5:1 in 5th gear, which might be a disadvantage. I'd say to choose the rpm you want at highway cruising speed and pick either a 5 speed or a 6 speed that will deliver that rpm with your rear end.
[Re: Sxrxrnr]
#1867013
07/09/15 12:50 AM
07/09/15 12:50 AM
kentj340
Cut and Shoot, TX
Simply put, 0.5:1 is a really excellent overdrive ratio if you have something close to 400 hp and a 3.73 rear end. My GTO with T56 will climb every hill I've ever encountered in 6th gear, which is 0.5:1, without downshifting.
In my opinion, an overdrive of 0.74:1 or close to that just isn't enough help to reduce engine rpms at highway cruising speed with a 3.73 rear end.
Here's the engine rpms from my car with T56 trans and 3.73 rear end at 70 mph:
4th gear, 1:1, 3250 rpm. 5th gear, 0.74:1, 2700 rpm. 6th gear, 0.50:1, 1800 rpm.
These are actual speedo and tach readings that are slightly different from theoretical (for example, 1800 is 0.55 x 3250).
Bottom line: a Passon 5 speed will only give you about 0.70:1. But it's a direct bolt in with no modifications. A T56 6-speed will give you 0.50:1 but modifications are needed.
The T56 does have two places to put the shift lever. It has a hydraulic slave/throw out bearing. Highly recommended: ventilate the bell housing with openings for air in and air out to blow the clutch dust out. Otherwise the slave may fail from the abrasive clutch dust. My closed tight system failed at 20,000 miles, and I added the ventilation with a new slave. Also recommended for T56 is the tickperformance.com clutch master cylinder kit and one person clutch bleeder line.
[Re: Spartan040]
#1867195
07/09/15 01:58 PM
07/09/15 01:58 PM
Posts: 441 Uranus
strokerchall
Uranus
why not bolt on a gearvendors to the 727? you can build a bullet proof 727 and still have options on gearing with a button.The 727 will bolt in easy,gearvendors easy bolt in,cut shaft and burn the sh!t out the tires
once you've stroked it,you'll wish you stroked it sooner
[Re: strokerchall]
#1867205
07/09/15 02:23 PM
07/09/15 02:23 PM
dogdays
Even in Houston, 0.5 x 3250 = 1625.
Gear ratios are not theoretical. That's one of the niceties of mechanical engineering.
On the other hand, speedometer and tachometer readings may be inaccurate, and that's where the discrepancy lies. If you knew what your tire revolutions per mile was, you could calculate everything else.
R.
[Re: Spartan040]
#1867427
07/09/15 10:31 PM
07/09/15 10:31 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
An brand new external linkage transmission will feel as good as a T56 with 150,000miles on it.
Forget the calculators, savings accounts, install set backs. Spend some seat time in both transmissions before you decide. You will not be dissapointed in the T56.
I stress this over and over again but I'm very picky about shift quality. If you don't really care about quick shifts and just need the overdrive, there are cheaper options than the T56.
[Re: Spartan040]
#1867860
07/10/15 07:42 PM
07/10/15 07:42 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
I have a Geforce built T56 behind a 1500 RWHP Viper and it stands up OK. Twin turbo Viper people do eventually break them and most then go to the newer versions but thats at 1000HP plus levels...
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: moparjimbo]
#1868083
07/11/15 02:49 AM
07/11/15 02:49 AM
kentj340
Cut and Shoot, TX
Something to know about a T56: it's easy to accidentally downshift to 1st gear at 60 mph when aiming for 3rd. I did that twice, and the rev limiter saved me by shutting off the ignition. And I clutched mighty fast.
If running a T56 with a computer-less engine, beware.
[Re: kentj340]
#1880429
07/29/15 12:03 AM
07/29/15 12:03 AM
Magnum
If running a T56 with a computer-less engine, beware. If it's the clutch spinning the engine up from an accidental downshift. A rev limiter will not limit the rpm.
