HP exhaust manifold heat riser #1862256
07/02/15 07:19 PM
07/02/15 07:19 PM
WASHINGTON
superbee471 Offline OP
WASHINGTON
Looking for a rebuild kit for my hp exhaust manifold heat riser. I have the round type, need the 2 springs but will take a whole kit if anyone knows where to get them.
Re: HP exhaust manifold heat riser [Re: superbee471] #1862264
07/02/15 07:29 PM
07/02/15 07:29 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Here is one source but not exactly cheap:
https://www.jimsautoparts.com/exhaust_manifold_hardware.htm
Re: HP exhaust manifold heat riser [Re: D_C] #1862283
07/02/15 07:49 PM
07/02/15 07:49 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
NOOOOO, NOT JIMS! tsk Megaparts has them in stock... up
http://www.megapartsusa.com/products.asp?cat=525
JB Rhinehart, Realist
A-Body's RULE!
Re: HP exhaust manifold heat riser [Re: Rhinodart] #1862377
07/02/15 10:19 PM
07/02/15 10:19 PM
D_C Offline
D_C  Offline
Still seems insanely expensive unless you are doing a concours restoration.
Before I would spend that much, I would be looking for used manifolds in junkyards to get a Spring and hardware store for bushings and straighten the plate and reweld.
Re: HP exhaust manifold heat riser [Re: superbee471] #1865823
07/07/15 12:45 PM
07/07/15 12:45 PM
WASHINGTON
WASHINGTON
Thank you for the info, I guess since Jims is the only one that has them you have got to pay the piper if you want the parts. I only need the spring, have already made the other parts myself, but you are right he is awful high priced. thank you again for the info.
Re: HP exhaust manifold heat riser [Re: superbee471] #1865902
07/07/15 03:22 PM
07/07/15 03:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOOOO .. DO NOT , repeat DO NOT buy from Jims , there are other places that have them , if Jim has them then others have them. I live within a couple of miles from Jim and I have not bought anything from them in almost 20 years.
which spring do you need ? I am going to Carlisle , I'll get it for you ...
