Plenum Pan replaced truck won't run - Update Fixed #1849535
06/15/15 12:50 PM
06/15/15 12:50 PM
Maine
P
Pkeel Offline OP
Pkeel  Offline OP
P
Maine
I need some help figuring out what I disconnected or failed to reconnect.
The story: I had oil loss and the plenum pan gasket failed. Took the weekend and I replaced the gasket. Put it all together and let the silicon gasket cure for 24 hours as per the instructions.
Today, I topped off the fluids and started the truck up. It won't run. If I sit in it and keep some pressure applied to the gas pedal it will run. I get a check engine light and as soon as I let off the gas it stalls. It is a quick stall, no sputtering or stuttering just a quick die.
I had a friend get in it and had them run the truck while I listened to it, I could not hear anything abnormal.
I can't find anything that is not connected.
Any hints or things I should look at would be greatly appreciated.
1999 Dodge Ram 1500 with a 5.2 liter Magnum.
Re: Plenum Pan replaced truck won't run [Re: Pkeel] #1849555
06/15/15 01:16 PM
06/15/15 01:16 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
When my 3.9 did that it was a failed IAC motor.
Re: Plenum Pan replaced truck won't run [Re: Pkeel] #1849598
06/15/15 02:23 PM
06/15/15 02:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Check the plug in on the IAC. It is the sensor looking thingy on the rear of the throttle body.
Re: Plenum Pan replaced truck won't run [Re: Pkeel] #1849600
06/15/15 02:24 PM
06/15/15 02:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You could spray some WD-40 in there throught the throttle body also.
Re: Plenum Pan replaced truck won't run [Re: Pkeel] #1849692
06/15/15 03:46 PM
06/15/15 03:46 PM
Maine
P
Pkeel Offline OP
Pkeel  Offline OP
P
Maine
It was indeed the IAC. I looked and it was not plugged in. I plugged it in and it made no difference. Threw a new one on and it is running really well again.
Thank-you bobby66 and HRDave.
The only issue left is a check engine light, but I will run it in somewhere and get it diagnosed if it does not reset on its own.
Re: Plenum Pan replaced truck won't run [Re: Pkeel] #1849791
06/15/15 06:58 PM
06/15/15 06:58 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Probably from the IAC being un plugged. Un-hook the batt, touch the two wire ends together, let it sit 5 minutes and hook it back up. That will clear the IAC code.
Re: Plenum Pan replaced truck won't run [Re: HotRodDave] #1861766
07/02/15 01:29 AM
07/02/15 01:29 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
If most likely loss it's idle memory when you had the battery unhooked. Try keeping it running and slowly remove your foot from the gas pedal may take a few minutes. Some times when you hook the battery up the idle motor retracts and is slow to extend back where it was.Carbon build up doesn't help it's respond either.
