70 challenger tach and speedo swap question #1861655
07/01/15 11:17 PM
07/01/15 11:17 PM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Getting ready to swap the tach and speedo on my 70 challeger ralley dash. Will they come out without removing the entire cluster housing? Can I just drop the steering column down and make enough room? TIA
Jess
Yeah, it's hopped up to over 160...
Re: 70 challenger tach and speedo swap question [Re: jt4406] #1861850
07/02/15 09:04 AM
07/02/15 09:04 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
I'd suggest taking the cluster out of the car; some might even suggest that pulling the entire dash is easier (and they're not necessarily wrong).
If you're pulling the cluster:
- lower the steering column
- protect the edges of the rallye dash bezel and top of the steering column with a few layers of masking tape
- remove the light bar
- remove the gauge bezel (removing the reset knobs first)
- you should then see the screws holding the gauge housing into place, along with the press-in fasteners that hold the lens
If you have small hands and/or are really agile, you may be able to swap those two gauges without going further. In any event
- disconnect the speedo cable and wiring to the back of the gauges
- remove the gauge housing
- remove the gauge lens
- it should be self-explanatory as to how the old speedometer and tach come out
- reverse the process
Re: 70 challenger tach and speedo swap question [Re: YYZ] #1862179
07/02/15 05:46 PM
07/02/15 05:46 PM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Thanks YYZ, for the reply. I got both changed out this morning. Went pretty much like you said, really wasn't too difficult. My car has air, so I had to drop the ac duct that runs under the steering column before the column itself. Now if it will stop RAINING here, I will test them out! Seems like it has rained every day for the last 3 weeks!
jt
