Re: alternator question
[Re: 340swing]
#1861605
07/01/15 10:47 PM
07/01/15 10:47 PM
RapidRobert
are you sayin one of the ammeter terminals in the ralley dash was loose & started smoking from the poor/loose connection right there? More info please
[Re: 340swing]
#1862345
07/02/15 09:30 PM
07/02/15 09:30 PM
Posts: 10,703 North Dakota
6PakBee
North Dakota
.....I switched it to the correct round back alternator and while idleing the ground wire to the alt meter got hot and started smoking(ralley dash) ..... Not trying to be a WA but there is no 'ground' on an ammeter. An ammeter is in series so both terminals are above ground.
[Re: 6PakBee]
#1862375
07/02/15 10:10 PM
07/02/15 10:10 PM
RapidRobert
What I would do is (1) take off the positive batt cable from its batt post. (2) take off the heavy red/black wires/ring terminals from the ammeter studs in the ralley dash and connect them all securely together to each other with a small bolt/nut thru the ring terminals. (3) back at the battery (with everything in the car shut off incl ign) see if you have any amperage draw on your meter in series between the batt positive cable and the batt positive post (meter on low amps scale). If NO draw (eng off), hook the cable back onto the post & then start it up with the ign key with your nose under the dash to immed check for continued smoking & shut it off if any smoking anywhere. if not smoking the (now isolated) ammeter/stud connections is the prob. If there IS a draw, dont start it up but dig in & find/fix the source of the improper draw first then see if the ammeter or elsewhere is bad (smoking).
[Re: 340swing]
#1862815
07/03/15 01:44 PM
07/03/15 01:44 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
Thanks for the suggestions i will try to fix it this weekend. The reason i assumed it was alternator related was it was fine with one alternator then after changing it with a unknown new to me alternator it smoked. I will check the loose stud first then go after the full field. thanks for the help ill let you know how it turns out. If you had a 35 amp alternator origninally and swapped in a 65 amp or bigger you may have ended up overloading the wires, Mopars are horrible on the bulkead and amp meter connection getting loose and corroded Good luck, let us know what you do and decide how to fix it
