Radial slicks ? #185098
01/05/09 09:15 PM
01/05/09 09:15 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I can get my hands on some 30 x 9 radial slicks that are used but in very good shape. I now run Hoosier QTP bias 29 x 11.5 tires. I thought I might give the radial slicks a try to see if the car likes them but I have never ran radial slicks. I have heard they are a bit faster. Anybody think its worth the trouble for me to mount them and try them ? Thanks , Ron
Re: Radial slicks ? [Re: 383man] #185099
01/05/09 09:18 PM
01/05/09 09:18 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
it would only be about 15$ to have some1 mount them.try them!
Re: Radial slicks ? [Re: blownzoom440] #185100
01/05/09 09:59 PM
01/05/09 09:59 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Na I can mount them myself. Ron
Re: Radial slicks ? [Re: 383man] #185101
01/05/09 10:06 PM
01/05/09 10:06 PM
I ran them then I was running a 30" tall tire...10-.15 quicker..more stable on the big end you run 20+ on air pressure in them...they wear out quick..
Re: Radial slicks ? [Re: 383man] #185102
01/05/09 10:09 PM
01/05/09 10:09 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
if they are hoosiers they have two different circs a 92.5 and a 94 or 95. if your car has more rpm left in the traps with the bias plies it might not with the radials they do not grow as much. I love mine went from a 28X12.5 et street to the short 30X10.5's my car loved 'em
Re: Radial slicks ? [Re: 68DART360] #185103
01/05/09 10:13 PM
01/05/09 10:13 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
go for it Ron!!!
Re: Radial slicks ? [Re: DJVCuda] #185104
01/05/09 10:27 PM
01/05/09 10:27 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
About a tenth to a tenth and a half quicker, but more rpm in the lights. Go for it!
Re: Radial slicks ? [Re: Kevins493] #185105
01/05/09 10:46 PM
01/05/09 10:46 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I knew they dont grow as much as my QTP Hoosier's so thats why I figure I may be ok since my Hoosier's are 29's and the radials are 30's. I like my trap rpm right now as its pushing 6300 in the lights but it still feels like it has some steam left. I think I will give it a try. Ron
Re: Radial slicks ? [Re: 383man] #185106
01/05/09 11:24 PM
01/05/09 11:24 PM
Locomotion Offline
Locomotion  Offline
The only bad thing about radial slicks compared to bias ply is that they are more sensitive to track conditions. They will have a tendency to spin sooner under marginal conditions and can spin worse when they do.
Personally, I use the lightweight, 94" circumference, 9" Hoosier radials.
Re: Radial slicks ? [Re: 383man] #185107
01/08/09 08:37 PM
01/08/09 08:37 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
I ran Hoosier 30x9 radial slicks. My Duster picked up .1 with them.
I didn't have trouble with them hooking until they were pretty well worn out.
Most of the time I ran 22 - 23 PSI.
One thing - You don't need to do John Force burn-outs with Radials. Spin em until the first puff of smoke and go.
You don't need to switch them from side to side either until they start to wear out.
I would get about 130 - 140 runs out of a set.
Radials are very popular with the Stock Eliminator crowd.
Re: Radial slicks ? [Re: 74DusterP457] #185108
01/08/09 08:46 PM
01/08/09 08:46 PM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
Hoosier rep told us to swap them after about 10 runs then only make a pass or 2 and swap them back. It makes a differance. We run Hoosier 10.5x30 radials. You are correct about the burnout. Just a little smoke and go.
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
