por 15 or rust bulet #184679
01/05/09 04:02 PM
01/05/09 04:02 PM
SCVpolara Offline OP
I tried this in the restoration with no responce.
Which do you prefer por 15 or rust bullet? Any tips or tricks when using these products? and who has used http://www.safestrustremover.com/default.asp
any advice?
Re: por 15 or rust bulet [Re: SCVpolara] #184680
01/05/09 04:16 PM
01/05/09 04:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Go here:
https://board.moparts.org/ubbthreads/search.php?Cat=0
Copy and paste this into the keyword search terms box:
+rust +bullet +por
Set the date range to "newer than 8 years" and hit submit. Then enjoy.
Re: por 15 or rust bulet [Re: DaytonaTurbo] #184681
01/05/09 04:35 PM
01/05/09 04:35 PM
Thanks I went thru all the posts. So doest anyone recomend using their metal blast?
