Re: piston cleaning blues [Re: Moparnut426] #184331
01/05/09 04:29 PM
01/05/09 04:29 PM
organ
maximum entropy Offline
organ
comet is better. not too much. maybe a cup or so. coffee grounds mixed with cinder will do in a pinch. iron filings are also excellent.
Re: piston cleaning blues [Re: maximum entropy] #184332
01/05/09 06:18 PM
01/05/09 06:18 PM
Detroit
TX91971 Offline
TX91971  Offline
Detroit
Hey guys he is probably right I worked with this bracket racer he would take his 100,000 mile 340 motor out every year and hone the cyl with a ball hone and put used rings back in the motor not the ones that came off the pistons because they were all broken and run most of the year consitent car 13.30's and when it would slow down he would take it out and replace the broken rings with other used rings. He also put cam bearings in with a long extension and hammer and it ran fine. I talked him into letting me put electronic ignition in his car in 1992. Dual points before that. When your on a budget that's the way it is. This guy was Heavy eleminator champ at a local pa track for many years in a row.
Re: piston cleaning blues [Re: TX91971] #184333
01/05/09 06:29 PM
01/05/09 06:29 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Will it run, sure. Will it be right, no. I understand all about budget and doing something cheap, but I still think it should be done right. Cast pistons are dirt cheap and a bore hone is not expensive. The whole process could likely be done for 150 bucks, with pistons. IMO, if you could not afford that, he should of just left the 250k shortblock assembled and went as is.....but I do realize that he was not asking for opinions, he only wanted to know how to get the carbon off. Seeing as that is the case, I am removing my from this discussion and should not have commented in the first place.
Monte
Re: piston cleaning blues [Re: Monte_Smith] #184334
01/05/09 06:51 PM
01/05/09 06:51 PM
Finally a HUSKER again
Moparnut426 Offline OP
Monte,
I totally understand where you are coming from, but in this case, The customer only has about X amount of $$$ and our machine shop charges about 350 to bore the block, and pistons cost 150ish, and then you have to press the old ones off, and press the new ones on, all costs money the customer just didnt have.
We will be fine.
Thanks and If it was mine, and I had the cash it would get bored, Never said it was a perfect world.
Not disagreeing with you at all, but certain things just have to work on a budjet.
Kasey
Re: piston cleaning blues [Re: Moparnut426] #184335
01/05/09 08:00 PM
01/05/09 08:00 PM
WA 98043
thecarfarmer Offline
WA 98043
Yeah, it'd be better to replace the pistons, but... I'd try some aircraft paint stripper if I was going to try and reuse 'em.
Aircraft stripper is formulated to not eat aluminum. Seems to me I put some on some carbon and it chewed through it like Rosanne Barr on a chunk of roast beef
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: piston cleaning blues [Re: Monte_Smith] #184336
01/06/09 05:06 AM
01/06/09 05:06 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Monte
150$ for a bore and hone WITH pistons?
Have I got some work for that shop you deal with !!!
Re: piston cleaning blues [Re: dOc !] #184337
01/11/09 10:07 PM
01/11/09 10:07 PM
Well I used paint stripper paist, and It wouked GREAT!! Thanks for the help, and I got 4 done in no time flat, I have 4 left, and 1 is soaking.
I appreciate the help guys
Kasey
Re: piston cleaning blues [Re: Monte_Smith] #184338
01/11/09 11:21 PM
01/11/09 11:21 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Monte
Good thang ya dudn't sugjezt a cam change Her's yer change
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: piston cleaning blues [Re: hemi-itis] #184339
01/12/09 01:26 AM
01/12/09 01:26 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
When I was a kid a local snowmobile racer would glass bead blast his pistons. Said it cleaned em up real nice but didnt effect the material.????? High school auto shop teacher would soak them in chem dip carb cleaner. (The shop had a 30 gallon drum) That was 20 years ago. I think the formula now is different and hard on metal?
Keep old mopars alive.
Re: piston cleaning blues [Re: 2boltmain] #184340
01/12/09 02:02 AM
01/12/09 02:02 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It's different but it's not that it's hard on metal...It's ineffective or carbon... EPA approved...
