Hand-Held/Mobile Air Compressor for Autocross and Home #1837289
05/30/15 01:58 PM
05/30/15 01:58 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
I'd like a hand-held air compressor for potential autocross and home use. It would be used just for adjusting tire pressure a couple psi for the track or for my daily commutes. What do you guys recommend?
Re: Hand-Held/Mobile Air Compressor for Autocross and Home [Re: MuuMuu101] #1837299
05/30/15 02:16 PM
05/30/15 02:16 PM
SoCal
SoCal
I found these that may look promising. Also, some people, doing a google search, recommend using a manual bike pump.
http://www.sears.com/craftsman-c3-19.2-v...directType=SRDT
http://www.amazon.com/Industries-MV50-SuperFlow-Hi-Compressor/dp/B000BM8RT8
Re: Hand-Held/Mobile Air Compressor for Autocross and Home [Re: MuuMuu101] #1837485
05/30/15 08:47 PM
05/30/15 08:47 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
http://www.amazon.com/Black-Decker-ASI300-120-Volt-Inflator/dp/B000IE0YIQ
I have one of these. Set the dial to the pressure you want, flip it on and walk away. 12v and 120v.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Hand-Held/Mobile Air Compressor for Autocross and Home [Re: MuuMuu101] #1837525
05/30/15 10:37 PM
05/30/15 10:37 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have a bottle of nitrogen about the size of a scuba tank. Fresh fill is about 2500psi. IIRC.
Mopar to the bone!!!
Re: Hand-Held/Mobile Air Compressor for Autocross and Home [Re: 72Swinger] #1837750
05/31/15 04:03 AM
05/31/15 04:03 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
another option is using the pump that comes in the newer cars, my 09 challenger had a pump that worked really well - I know I used mine a lot. I got really good at plugging tires on that car, it was a magnet for nails....
Re: Hand-Held/Mobile Air Compressor for Autocross and Home [Re: MuuMuu101] #1840537
06/03/15 03:01 PM
06/03/15 03:01 PM
NY NY
3
340duster340 Offline
NY NY
I would go with a Viair or arb unit. Their stuff is designed for off-road and is really good quality.
I made the mistake of getting the harbor freight 150psi 12v confessor and it's slightly better than junk.
Your going to want a continuous duty pump which is worth paying for.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
