pushrod rubbing heads grind for clearance???
#183571
01/04/09 01:29 PM
01/04/09 01:29 PM
Posts: 4,671 On the parachute mount
n20mstr
Upon disassembly, im finding that even thought the pushrods have .050 or so clearance, in some spots they are slightly rubbing. I see a very slight polishing on the pushrods and the same on the heads. The pushrods are rotating because its all the way around in one spot and very slight(Indy 440-1's and Smith bro pushrods) Now im tempted to grind the heads just a little in the polished spots, but im reconsidering that the pushrods need that little "support" They dont touch when the engine is on the stand...they have clearance (I already ground the heads and block for the clearance) Should i touch them up or leave it?? No problems so far roughly 200 passes like this
....BAD A$$ STREET CAR.....
Re: pushrod rubbing heads grind for clearance???
[Re: MR_P_BODY]
#183574
01/04/09 01:41 PM
01/04/09 01:41 PM
Posts: 5,617 long island NY
Ari440
long island NY
are thet 3/8ths or 7 1/6ths pushrods they should not be touching or rubbing
1.39 9.85 - 137 mph
[Re: n20mstr]
#183576
01/04/09 02:04 PM
01/04/09 02:04 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
Did you check the clearances in the motor cold and all the way through the lift cycle opening and closing? If not do that first, if the ones rubbibg clear then the pushrods are probaly flexinf enough in the problem spots to rub. Manton syas there is nothing wrong with aving extra pushrod support as long as the motor isn't making metal or killing the pushrod cups due to the pushrod not allowing oil into the cup and adjuster seat I have found ut the hard way that you don't want a Hemi pushrod rubbing becuase it can kill the rocker end of the pushrods do to lack of oil in the pushrod cup. I had to replace three exhaust single tapered pushrods in one of my customers motors, at $24.00 a piece, back in the mid 1990 due to my allowing thme to rub to much there are a lot of pushrods running in motors all across the country that are living well without causing problems, they shine where they rub
[Re: 69Cuda340S]
#183581
01/04/09 06:25 PM
01/04/09 06:25 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Normally "slight" rubbing ( as you seem to be explaining ) isnt a huge issue. I am a Manton WD dealer and they recommend only .010 clearance and many times the slight rubbing is fine. I used to over-clearance these areas but have since changed my ways and found it to be better.Its not a problem to have that support, but I would also guess that a thicker walled pushrod could be a good thought in your case knowing somethings about your combo and ET as you have posted before.
RIP Monte Smith
[Re: CompWedgeEngines]
#183582
01/04/09 06:29 PM
01/04/09 06:29 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
I agree slight rubbing is not an issue. .050" is plenty of clearance for a pushrod, maybe even a bit more than necessary IMO. If it spins over fine on the stand and has that much clearance dont worry about it. Many would argue that the slight rubbing is acting like a "guide plate" of sorts to help stabilize the pushrod. I tend to agree. If it is only slight rubbing dont sweat it.
[Re: Sport440]
#183585
01/04/09 10:39 PM
01/04/09 10:39 PM
n20mstr
i read the info on Mantons site, i will double check my clearance while assembling the engine this time, but yea its rubbing VERY little, and even at that, its only on the intakes and all its doing is putting a slight polish on the pushrods. I remmeber having smallblocks that had the large cork gastkets rubbing the pushrods and that left more of a mark on there than this...Thanks for all the replies
